Browse Forums Building A New House Re: HELP! External Sheathing on a timber frame. Builder unsu 4Mar 04, 2024 4:39 pm Good to have, but it is not really mandatory, from what I know. You have waterproof retaining wall in front, so should be fine. I am only worried about this section above the wall which certainly has to be covered somehow. Re: HELP! External Sheathing on a timber frame. Builder unsu 5Mar 04, 2024 7:41 pm alexp79 Good to have, but it is not really mandatory, from what I know. You have waterproof retaining wall in front, so should be fine. I am only worried about this section above the wall which certainly has to be covered somehow. Thanks Alex, there will be single leaf of bricks from the top of the retaining wall to the floor above so the space will effectively be closed off from external elements. I thought there should at least be some house wrap if not sheathing as well. Re: HELP! External Sheathing on a timber frame. Builder unsu 6Mar 05, 2024 8:06 pm Sheathing is a US term, they sheath their houses in plywood, we only use sections of ply for bracing. No requirement for reflective foil/ membrane here either but you can add one if you like. It is not an external wall assuming the underfloor space is closed off. The insulation can be kept in place by stringing between studs. Re: HELP! External Sheathing on a timber frame. Builder unsu 7Mar 06, 2024 1:17 pm Pulse Sheathing is a US term, they sheath their houses in plywood, we only use sections of ply for bracing. No requirement for reflective foil/ membrane here either but you can add one if you like. It is not an external wall assuming the underfloor space is closed off. The insulation can be kept in place by stringing between studs. Thanks Pulse, thats really helpful and very much appreciated. Also thanks for the pointer on sheathing, thats me watching too many american youtube videos! Thanks for responding. Do you know of anyone installing this product in Sydney? 2 4085 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2995 This is 100% true. You can not hang anything on steel frames. very frustrating 8 10374 |
