Browse Forums General Discussion Re: Solar Panel Installation 7Feb 21, 2024 3:02 pm Althom kumar2015 What would be the better option - Is it better to install solar on Duplex units from builder (3kw $3500-$5500 per unit) or hire a solar company later to install this ? I know it can be little bit lesser, but heard many stories about installation on the roof and damaging it, etc. Please suggest the nominal price range for 3kw instllation with panels, invertors, batteries. $3500 for a 3.3 kW setup? Your builder is applying a markup of about 100% and is having a lend of you. For that price you'd be able to install 6.6kW easily This was two years ago. I'm sure the prices have dropped since then. Re: Solar Panel Installation 8Apr 24, 2024 4:22 pm Also, if you get the builder to install/supply, they have the option to take the Gov. STCs. Can add up to a couple of thousand in their pocket.. I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5424 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6448 |
