Browse Forums Building A New House Re: New custom build - Floor plan - Need feedback 5Oct 17, 2023 1:17 pm Thank u ... will be keen to see your changes. There is only a 1.5 m slope upwards on the building envelope so not too steep. The highest point is at the top far ocrner of the block and we will be atleast 10m away from it. I can send you a draft site plan if that helps. Re: New custom build - Floor plan - Need feedback 6Oct 17, 2023 1:23 pm Prats09 Thank u ... will be keen to see your changes. There is only a 1.5 m slope upwards on the building envelope so not too steep. The highest point is at the top far ocrner of the block and we will be atleast 10m away from it. I can send you a draft site plan if that helps. yes please...include direction of north and any views as well as approx distance to all boundaries... i've done a rough draft of my suggestions but having problems uploading Re: New custom build - Floor plan - Need feedback 7Oct 17, 2023 2:43 pm oklouise Prats09 Thank u ... will be keen to see your changes. There is only a 1.5 m slope upwards on the building envelope so not too steep. The highest point is at the top far ocrner of the block and we will be atleast 10m away from it. I can send you a draft site plan if that helps. yes please...include direction of north and any views as well as approx distance to all boundaries... i've done a rough draft of my suggestions but having problems uploading attached first variations Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi there! Absolutely agree on the wasted space. We have no desire for the master to be that oversized, but it occurred when we increased the depth of the garage. We have… 4 12893 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25583 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 21274 |
