Browse Forums General Discussion Re: Strange noise in the walls 3Sep 04, 2023 4:58 am Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Strange noise in the walls 6Sep 04, 2023 8:01 pm Everything expands and contracts, the fault is with the builder not the window manufacturer. Not allowing for it causes the noise . You could shade the windows externally and see if it is reduced, thereby ruling it out.
Re: Strange noise in the walls 9Mar 23, 2024 6:01 pm agus Hi rob, any improvements with the noise you’ve experienced? Hi, no, still a daily thing, at certain points in the day of I push firmly against the wall I can recreate the noise. I'm wondering if it's the metal wall ties moving due to thermal expansion / contraction. Aside from removing the plaster and seeing if I can secure the toes I'm not sure what else I can do Re: Strange noise in the walls 10Mar 23, 2024 6:24 pm Can you hear it from outside the house? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Strange noise in the walls 11Mar 23, 2024 6:37 pm Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This creates the noise and then it stops for the evening. I think I'll have to remove the plasterboard and leave it open for a few days to see if I can get a better look at exactly where the noise is coming from. Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11301 Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window… 4 12629 2 4266 |
