Browse Forums Heating, Cooling & Insulation 1 Sep 02, 2023 9:35 pm Hi Have had a few new Mitsubishi Heavy Industries (SRK25ZSA-W) aircons recently installed. They don't appear to be installed flush with the wall and can visually see the holes in the back of the wall. Is this normal for this particular model or have they been installed incorrectly. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Newly Installed Aircon Not Sitting Flush with the Wall 3Sep 04, 2023 7:56 pm The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might need to be looked at. Send the installer photos Hey, I'm wanting to make an above ground pond that will sit on our patio, it will be 2m x 1m x 60cm high. I'm just wanting to run a few things by people to verify my… 0 1237 Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 4137 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 3300 ![]() |
