Browse Forums General Discussion Re: Sewer pipes under slab 3Aug 27, 2023 11:48 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Sewer pipes under slab 4Aug 27, 2023 12:02 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Sewer pipes under slab 5Aug 27, 2023 1:14 pm SaveH2O Below is a link to a post by a leading slab heave expert. viewtopic.php?p=1206402#p1206402 Also, if AS 2870 is referenced in the contract, make sure it is not only referenced to the slab which is construction. It must also be referenced as plumbing if you want to include flexible joints etc. Thanks that link in particular is really useful. To me, that's what it looks like: poor backfilling and/or compaction. The width is about 1000mm maybe. That conduit in the photo is for the NBN. The water is about… 4 11908 New home owners are strongly advised to have a forensic examination of all drain, storm water and sewer pipes prior to handover. 15 39118 Did you end up finding out what caused this... I might have same issue in ny house in Keilor East 2 6157 |
