Browse Forums Building A New House 1 Aug 15, 2023 4:46 pm I was wondering on how hard for architects/builders to change an existing CDC plan where the general building comments says brick veneer to a double brick build? Re: How hard to change CDC plan for a brick veneer to double 2Aug 15, 2023 5:02 pm iwanttobuildsyd I was wondering on how hard for architects/builders to change an existing CDC plan where the general building comments says brick veneer to a double brick build? Its very simple to get a modification done, but you will need the structural plans updated and stamped as well cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: How hard to change CDC plan for a brick veneer to double 3Aug 15, 2023 5:06 pm Ashington Homes iwanttobuildsyd I was wondering on how hard for architects/builders to change an existing CDC plan where the general building comments says brick veneer to a double brick build? Its very simple to get a modification done, but you will need the structural plans updated and stamped as well cheers Simeon Thanks for the info, whats the usual turn-around for these processes? Re: How hard to change CDC plan for a brick veneer to double 4Aug 15, 2023 5:13 pm iwanttobuildsyd Ashington Homes iwanttobuildsyd I was wondering on how hard for architects/builders to change an existing CDC plan where the general building comments says brick veneer to a double brick build? Its very simple to get a modification done, but you will need the structural plans updated and stamped as well cheers Simeon Thanks for the info, whats the usual turn-around for these processes? depends on your team. Mine does it in like a week Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: How hard to change CDC plan for a brick veneer to double 5Aug 15, 2023 5:36 pm How about for the actual council/nsw portal? How long do they take if plans are all good to go? Re: How hard to change CDC plan for a brick veneer to double 6Aug 15, 2023 5:49 pm iwanttobuildsyd How about for the actual council/nsw portal? How long do they take if plans are all good to go? depends on your council, some 1 day some 14 days Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 5565 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 8021 DIY, Home Maintenance & Repair fair question about the slope. Re soil I mean that it doesn't look like reactive clay which swells and shrinks with wetness/dryness. If the floors in your house are… 3 20720 |
