Browse Forums General Discussion Re: Butchered concrete over overflow relief gully 2Jul 01, 2023 5:41 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Butchered concrete over overflow relief gully 3Jul 01, 2023 5:48 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Butchered concrete over overflow relief gully 4Jul 01, 2023 5:58 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Butchered concrete over overflow relief gully 5Jul 01, 2023 6:05 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Butchered concrete over overflow relief gully 7Jul 01, 2023 8:27 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Butchered concrete over overflow relief gully 8Jul 02, 2023 1:34 am Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Butchered concrete over overflow relief gully 9Jul 02, 2023 10:30 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Butchered concrete over overflow relief gully 11Jul 03, 2023 9:04 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Butchered concrete over overflow relief gully 12Jul 03, 2023 9:14 am Adeez The appearance although not great has been the least of my worries. The issue I raised was that I believe that there is risk of stormwater getting into the ORG. The concrete should have been created in a dome like shape around it. There would have to be a lot for that cap to over flow. But still..perhaps I can place another open cap over it or something Dont think storm water getting in is going to matter one bit. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Butchered concrete over overflow relief gully 13Jul 03, 2023 6:30 pm Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather than have a raised hump that you trip over or snags the bin when you drag it down the side. Even that concreting isn't that bad. It may be slightly poorly finished but overall a bit of a clean up and it would be fine. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10739 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5952 Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. 7 9326 |
