Browse Forums General Discussion Re: Butchered concrete over overflow relief gully 2Jul 01, 2023 5:41 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Butchered concrete over overflow relief gully 3Jul 01, 2023 5:48 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Butchered concrete over overflow relief gully 4Jul 01, 2023 5:58 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Butchered concrete over overflow relief gully 5Jul 01, 2023 6:05 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Butchered concrete over overflow relief gully 6Jul 01, 2023 7:24 pm building-expert Can you post another photo showing concrete in relation to weep holes. It may be that the concrete has been set too high. Attached photo below. There is plenty of distance between weepholes. I made sure that there was minimum 75mm for all. I also asked for 50mm fall over 1m for which they have said they have done. My issue is that the ORG looks to be level with the concrete. It seems at risk for stormwater to get in... The adjacent side also does not have a gap between the concrete to the wall. The is one drain to the front of the ORG and one further back. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Butchered concrete over overflow relief gully 7Jul 01, 2023 8:27 pm Adeez building-expert Can you post another photo showing concrete in relation to weep holes. It may be that the concrete has been set too high. Attached photo below. There is plenty of distance between weepholes. I made sure that there was minimum 75mm for all. I also asked for 50mm fall over 1m for which they have said they have done. My issue is that the ORG looks to be level with the concrete. It seems at risk for stormwater to get in... The adjacent side also does not have a gap between the concrete to the wall. The is one drain to the front of the ORG and one further back. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Org should be close to the wall so as not to be tripping hazard in the paving and should be under external tap so that water seal is replenished. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Butchered concrete over overflow relief gully 8Jul 02, 2023 1:34 am Adeez What is your issue with the concreting? As mentioned, it may not be the prettiest concreting but functionally it's fine. The level of the concreting is as I would expect and gives you the flattest finish possible. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Butchered concrete over overflow relief gully 9Jul 02, 2023 10:30 pm The finished job must not only have the functionality of utility but also the functionality of appearance. Trades are trained not only to do a good job but also job that looks good, in line with what would be expected from a trade skilled in his art. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Butchered concrete over overflow relief gully 10Jul 03, 2023 8:50 am The appearance although not great has been the least of my worries. The issue I raised was that I believe that there is risk of stormwater getting into the ORG. The concrete should have been created in a dome like shape around it. There would have to be a lot for that cap to over flow. But still..perhaps I can place another open cap over it or something Re: Butchered concrete over overflow relief gully 11Jul 03, 2023 9:04 am Adeez The appearance although not great has been the least of my worries. The issue I raised was that I believe that there is risk of stormwater getting into the ORG. The concrete should have been created in a dome like shape around it. There would have to be a lot for that cap to over flow. But still..perhaps I can place another open cap over it or something Yes it should be raised but then you will have tripping risk, it’s in the wrong location, talk to your plumber. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Butchered concrete over overflow relief gully 12Jul 03, 2023 9:14 am Adeez The appearance although not great has been the least of my worries. The issue I raised was that I believe that there is risk of stormwater getting into the ORG. The concrete should have been created in a dome like shape around it. There would have to be a lot for that cap to over flow. But still..perhaps I can place another open cap over it or something Dont think storm water getting in is going to matter one bit. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Butchered concrete over overflow relief gully 13Jul 03, 2023 6:30 pm Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather than have a raised hump that you trip over or snags the bin when you drag it down the side. Even that concreting isn't that bad. It may be slightly poorly finished but overall a bit of a clean up and it would be fine. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10742 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5953 Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. 7 9326 |
