Browse Forums Landscape & Garden Design Re: Dry Well in the backyard 2Jun 15, 2023 1:07 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Dry Well in the backyard 5Jun 15, 2023 10:21 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Dry Well in the backyard 7Jun 19, 2023 6:34 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Dry Well in the backyard 9Jun 20, 2023 10:22 am I have no idea! I can only surmise as I have done without being on site and doing some excavation but the three pipes tend to rule out it being a small dedicated well. It's an interesting topic and all I can say is that the answers may require some digging to determine the original purpose of the 3 pipes. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Dry Well in the backyard 10Jun 21, 2023 10:27 am SaveH2O I have no idea! I can only surmise as I have done without being on site and doing some excavation but the three pipes tend to rule out it being a small dedicated well. It's an interesting topic and all I can say is that the answers may require some digging to determine the original purpose of the 3 pipes. I thought this may be designed to soak well. so the third pipe just goes to the ground. Re: Dry Well in the backyard 11Jun 21, 2023 12:09 pm It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full and it appears that it never empties. What is your soil type? Soak wells need sandy soils. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. DIY, Home Maintenance & Repair Ditto 3M Claw, expensive but best thing I've used to date. I put two of the 11kg ones in for a 12kg mirror on the wall, and its been great for 4 years now. 4 2496 Finally got the Soakwell at my house sucked out. Now I’m looking for ideas on how to hide it as it’s a bit of an eye sore. I’m thinking I’d like to turf over the… 0 4125 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25348 |
