Browse Forums General Discussion Re: Roof Plumbing - no compliance certificate ? 2Jun 18, 2023 8:59 am just get a licensed plumber to inspect and sign off make sure you explain what happened not that you performed the work you will need to contact a few to get someone to help out Re: Roof Plumbing - no compliance certificate ? 3Jun 18, 2023 11:48 am aussieta just get a licensed plumber to inspect and sign off make sure you explain what happened not that you performed the work you will need to contact a few to get someone to help out Thanks for that aussieta. I will update this thread once it is all resolved to help anyone in the future that ends up in the same situation Re: Roof Plumbing - no compliance certificate ? 4Jul 04, 2023 9:32 am For anyone that comes across this issue in the future - Just did what aussieta said and found a plumber to inspect it and sign off on it. Was difficult to find someone to come around and have a look at it but we got there in the end. Thanks again Re: Roof Plumbing - no compliance certificate ? 5May 16, 2024 8:56 am I can totally relate to your shed project struggles—I recently tackled a similar ordeal, and it was quite the journey. Navigating through all those regulations and hoops to jump through can be downright exhausting! From a pure legal perspective, if you've signed the variation, it is a very high bar to have it set aside. No-one can give you legal advice on a forum, but you would need… 3 5591 3 4665 |
