Browse Forums General Discussion Re: Cracking and popping noises in roof and walls 7Oct 01, 2020 6:48 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Cracking and popping noises in roof and walls 8Oct 02, 2020 6:49 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Cracking and popping noises in roof and walls 11Oct 05, 2020 9:31 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Cracking and popping noises in roof and walls 13May 22, 2023 10:33 pm Easy007 Hi All, I am new to this forum. I have a 3 yr old house and have recently started hearing cracking and popping noises from roof and wall of my house. There are no cracks internally or externally in the house. Should I be worried about this? hey, did you manage to find those strange popping nd craking sounds from roof? getting similar sounds from my tiles roof of recently purchased property. Structural inspector said no fault at all in structure of this 10yr old house. Re: Cracking and popping noises in roof and walls 14May 23, 2023 7:37 am I thought it was common for new and old houses to make expanding and contracting noises. Especially those with timber trusses... It takes half your life before you discover life is a do-it-yourself project. - Napoleon Hill Re: Cracking and popping noises in roof and walls 15May 23, 2023 8:56 am DIY_Debbie I thought it was common for new and old houses to make expanding and contracting noises. Especially those with timber trusses... it is to a degree, but these sounds tend to be fairly obvious so when you hear something out of the ordinary it can be concerning. Re: Cracking and popping noises in roof and walls 16May 23, 2023 9:15 am ponzutwo DIY_Debbie I thought it was common for new and old houses to make expanding and contracting noises. Especially those with timber trusses... it is to a degree, but these sounds tend to be fairly obvious so when you hear something out of the ordinary it can be concerning. Agree, and the frequency is high too. I put lots of efforts to identify the trusses, loose water pipes etc which could be the main culprits, even put cctv cameras around the ceiling but no success. Ain't that the truth! We used to have a tile roof and had it replaced with colorbond and suddenly everything throughout the entire house sounds louder! 4 7339 0 1607 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11451 |
