Browse Forums Building A New House Re: Need some advice on the design 8May 07, 2023 1:20 pm oklouise I thought you asked for the master bedroom facing the backyard?? ...please list what you want for every room and i will attempt to provide what you want We actually found out that the 42 is actually better. Here is some more information about our block and requirements: 1. The backyard is north east facing 2. It is 20 meters wide 3. We prefer more bedrooms facing backyard 4. Not having the ensuites facing street though as it would look bit odd Some thinking about your design: 1. Prefer not having the wall just in front of the end of stairs at first floor as the landing will seem cramped 2. Prefer not having the storage replacing the rail on first floor as it would make the void look boxed Could you please attempt on the 42 floor plan which can be found at https://www.clarendon.com.au/nsw/home-d ... aratoga-42? Re: Need some advice on the design 9May 07, 2023 5:17 pm Iwantnewhouse oklouise I thought you asked for the master bedroom facing the backyard?? ...please list what you want for every room and i will attempt to provide what you want We actually found out that the 42 is actually better. Here is some more information about our block and requirements: 1. The backyard is north east facing 2. It is 20 meters wide 3. We prefer more bedrooms facing backyard 4. Not having the ensuites facing street though as it would look bit odd Some thinking about your design: 1. Prefer not having the wall just in front of the end of stairs at first floor as the landing will seem cramped 2. Prefer not having the storage replacing the rail on first floor as it would make the void look boxed Could you please attempt on the 42 floor plan which can be found at https://www.clarendon.com.au/nsw/home-d ... aratoga-42? placing all bedrooms across the back would need a wall opposite the top of the stairs, bathrooms at the sides and lots of empty space across the front to be used for a living area and what else?? and there needs to be some wall around the stairs to support the roof and create some privacy but do you want an open stairwell at the cost of storage and bedroom sizes..and keep in mind that widening the house also makes more space downstairs that could be used for a rumpus room and bigger guest suite and MPR but that makes the whole house about 450sqm!!! assuming that you will only use Clarendon to build a variation of their floor plan do they have a limit to the variations allowed and what is the maximum size possible with your budget? Re: Need some advice on the design 10May 07, 2023 10:05 pm oklouise Iwantnewhouse oklouise I thought you asked for the master bedroom facing the backyard?? ...please list what you want for every room and i will attempt to provide what you want We actually found out that the 42 is actually better. Here is some more information about our block and requirements: 1. The backyard is north east facing 2. It is 20 meters wide 3. We prefer more bedrooms facing backyard 4. Not having the ensuites facing street though as it would look bit odd Some thinking about your design: 1. Prefer not having the wall just in front of the end of stairs at first floor as the landing will seem cramped 2. Prefer not having the storage replacing the rail on first floor as it would make the void look boxed Could you please attempt on the 42 floor plan which can be found at https://www.clarendon.com.au/nsw/home-d ... aratoga-42? placing all bedrooms across the back would need a wall opposite the top of the stairs, bathrooms at the sides and lots of empty space across the front to be used for a living area and what else?? and there needs to be some wall around the stairs to support the roof and create some privacy but do you want an open stairwell at the cost of storage and bedroom sizes..and keep in mind that widening the house also makes more space downstairs that could be used for a rumpus room and bigger guest suite and MPR but that makes the whole house about 450sqm!!! assuming that you will only use Clarendon to build a variation of their floor plan do they have a limit to the variations allowed and what is the maximum size possible with your budget? Yeah, It would be impossible to have all bedrooms facing back. I think we just want to have as many as possible, e.g. 2 or 3 bedrooms. And yes we would prefer to have open stair over storage as we think it should be fine as each bedroom would have wardrobe anyway. The current room size, 3.x * 4.x should be good enough? I agree, we probably don't need rumpus anymore as the house is already over 400sqm. No need to extend the house. Re: Need some advice on the design 11May 11, 2023 8:41 am Iwantnewhouse oklouise I thought you asked for the master bedroom facing the backyard?? ...please list what you want for every room and i will attempt to provide what you want We actually found out that the 42 is actually better. Here is some more information about our block and requirements: 1. The backyard is north east facing 2. It is 20 meters wide 3. We prefer more bedrooms facing backyard 4. Not having the ensuites facing street though as it would look bit odd Some thinking about your design: 1. Prefer not having the wall just in front of the end of stairs at first floor as the landing will seem cramped 2. Prefer not having the storage replacing the rail on first floor as it would make the void look boxed Could you please attempt on the 42 floor plan which can be found at https://www.clarendon.com.au/nsw/home-d ... aratoga-42? widening the whole house allows for 4 bedrooms across the back separated by the wiw for parents' privacy and a the more private bedroom on the front could be for the oldest child ...downstairs inlcudes an optional rumpus and total size is still under 400sqm but with small variations there should be enough space for a triple garage and/or drive through to the backyard plus my original alfresco iwantnewhouseupstairsLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ iwantnewhousedownstairsLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Need some advice on the design 12May 11, 2023 1:14 pm oklouise Iwantnewhouse oklouise I thought you asked for the master bedroom facing the backyard?? ...please list what you want for every room and i will attempt to provide what you want We actually found out that the 42 is actually better. Here is some more information about our block and requirements: 1. The backyard is north east facing 2. It is 20 meters wide 3. We prefer more bedrooms facing backyard 4. Not having the ensuites facing street though as it would look bit odd Some thinking about your design: 1. Prefer not having the wall just in front of the end of stairs at first floor as the landing will seem cramped 2. Prefer not having the storage replacing the rail on first floor as it would make the void look boxed Could you please attempt on the 42 floor plan which can be found at https://www.clarendon.com.au/nsw/home-d ... aratoga-42? widening the whole house allows for 4 bedrooms across the back separated by the wiw for parents' privacy and a the more private bedroom on the front could be for the oldest child ...downstairs inlcudes an optional rumpus and total size is still under 400sqm but with small variations there should be enough space for a triple garage and/or drive through to the backyard plus my original alfresco iwantnewhouseupstairsLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ iwantnewhousedownstairsLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 Hi guys, I'm planning on reorganizing my bedroom completely so any kind of advice will be helpful since i have zero knowledge about interior design, matching colors,… 0 3547 Hi VK, Think it's worth investing time in an Owner Builder course to equip you with basic knowledge on Australian Building Industry and its regulations. Also, I suggest… 11 24475 Hi all, Need some ideas for my front yard. There are a few elements where the landscaping needs to take into account: There is a slight slope forward with steps going to… 0 3163 |
