Browse Forums DIY, Home Maintenance & Repair Re: Rusting steel posts 14Mar 17, 2023 8:38 pm Ardo Seriously I would go for the zinc anode primer and wire brush. Hard to reach places can be done with a hand held sandblaster. It's not a huge mess at all. You could even drill a hole in each post and use rust converter as a spray inside the post. Get another 25 years out of those posts. Fair enough. I've dug out two of mine that were not set in proper footings and they are in very bad condition below. Plus the welds at the top of a couple are pretty shot. I may be going over the top, but my kids play on that balcony and I don't want to have to worry about it. Cheers Re: Rusting steel posts 16Mar 18, 2023 11:20 am tsfreo Ardo Seriously I would go for the zinc anode primer and wire brush. Hard to reach places can be done with a hand held sandblaster. It's not a huge mess at all. You could even drill a hole in each post and use rust converter as a spray inside the post. Get another 25 years out of those posts. Fair enough. I've dug out two of mine that were not set in proper footings and they are in very bad condition below. Plus the welds at the top of a couple are pretty shot. I may be going over the top, but my kids play on that balcony and I don't want to have to worry about it. Cheers I suggest you get advice from your local council building surveyor That will need to be inspected by a structural engineer. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs 4 3989 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14838 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8980 |
