I wanted to check what is the biggest house GFA allowed by CDC excluding granny 60sqm on a 900sqm lot
Is it 430 - 60 = 370sqm ? or 380 - 60 = 320sqm ?
Browse Forums Building A New House Re: What is the max size of House can be built with CDC cod 2Mar 09, 2023 5:33 am Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: What is the max size of House can be built with CDC cod 3Mar 09, 2023 5:52 am ![]() ![]() I wanted to check what is the biggest house GFA allowed by CDC excluding granny 60sqm on a 900sqm lot Is it 430 - 60 = 370sqm ? or 380 - 60 = 320sqm ? For a normal rectangle lot In real terms you will comfortably fit a 450 sqm house, maybe larger with a bigger alfresco and some voids. There are a lot of factors that come into play which will determine the maximum GFA like lot shape, depth, width, setback of your neighbours houses etc. In the area we mainly build we get a lot of 900 sqm lots and are doing some closer to 500 sqm, my own lot is 910sqm but it has a 34m frontage and 7m rear boundary so with the setbacks I only managed to fit 447sqm. I hope this helps Cheers Simeon Is this DA or CDC you mean? I thought CDC more restrictive than DA Even Hornsby LEP/DCP 2013 restricts 430sqm GFA for a DA, and in my area doesn't classify 0.5 FSR. and then I found this - which is very confusing 380sqm [may be I am missing something] https://legislation.nsw.gov.au/view/htm ... 2#sec.3.19 Re: What is the max size of House can be built with CDC cod 4Mar 09, 2023 6:10 am ![]() ![]() ![]() I wanted to check what is the biggest house GFA allowed by CDC excluding granny 60sqm on a 900sqm lot Is it 430 - 60 = 370sqm ? or 380 - 60 = 320sqm ? For a normal rectangle lot In real terms you will comfortably fit a 450 sqm house, maybe larger with a bigger alfresco and some voids. There are a lot of factors that come into play which will determine the maximum GFA like lot shape, depth, width, setback of your neighbours houses etc. In the area we mainly build we get a lot of 900 sqm lots and are doing some closer to 500 sqm, my own lot is 910sqm but it has a 34m frontage and 7m rear boundary so with the setbacks I only managed to fit 447sqm. I hope this helps Cheers Simeon Is this DA or CDC you mean? I thought CDC more restrictive than DA Even Hornsby LEP/DCP 2013 restricts 430sqm GFA for a DA, and in my area doesn't classify 0.5 FSR. and then I found this - which is very confusing 380sqm [may be I am missing something] https://legislation.nsw.gov.au/view/htm ... 2#sec.3.19 We are not far from you, next council over but that doesn't matter as CDC is generic. In the most simplest of terms, there are a lot of tricks to using the GFA guidelines and exclusions which an experienced designer can exploit for you. Even with Hornsby guidelines there will be a number of items that will be excluded from your GFA calculation. It varies from council to council. We are building one home on a 923sqm block in Kur-ring-gai and we have 511 sqm, but it has a large alfresco which is excluded which is why we are over 500sqm. Best advice I can give you is to get a survey and get a preliminary design done to work out what you can fit. cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 6901 you need to make an application to your local council for this as they are the approval authority for driveways cheers Simeon 1 7626 ![]() |
