Browse Forums General Discussion 1 Feb 20, 2023 9:11 pm HI i just had the fascias replaced on 1960's home and the old soffits dont reach the new colourbond fascia (usually the soffits fit in the groove - the tradesmen put on the fascias straight and square in the correct manner but the house is old and the soffits are not flat - there is gaps from 5mm -25mm all up the house from the edge of the soffit to the back of the fascia - so does anyone have any suggestions how to extend the soffits or cover the gaps ? thaks for the help Mark Re: soffits dont reach fascia Help to fix 3Mar 14, 2024 12:04 pm Be careful, the soffits may contain asbestos Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: soffits dont reach fascia Help to fix 4Jun 07, 2024 2:31 am If the soffits don't reach the fascia after replacing them, consider installing a J-channel or a trim piece to cover the gaps. Another option is to custom-cut additional soffit material to fit the gaps. Still, be careful whom you trust in this work. If the gaps are not covered properly, you can have severe problems in the future, like roof leaks, mold, pest infestation, etc. Better consult a professional before starting the work. I suggest you use the services of the guys from iReno Eavestrough and Siding. Two years ago, I needed to replace a part of the soffit on the eastern side of the roof, and the guys did the job well. DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 13473 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 16309 |
