Browse Forums Building A New House Re: Help !! Redo Colorbond Roof Installation 3Feb 18, 2023 10:50 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Help !! Redo Colorbond Roof Installation 5Feb 18, 2023 3:49 pm ![]() Hey chars0974 They will remove, insulate and refit the existing roof in small sections. The new insulation will be properly laid, lapped and fixed in accordance with the manufacturers recommendations Damaged sheets and flashings are to be replaced Make sure you photo/video the entire roof first, put everything in writing. The same must be done to the underside/ inside the roof re. sheet fixings per wind rating requirements. Any damage caused when undertaking the remedial work is the responsibility of the builder and has to be repaired by the builder You've just highlighted the importance of proper inspections before and during construction. The builder generally withholds payment from the roof plumber until the works done...you'll need to keep an eye on how well its done...Advise you are preparing to withhold/delay the progress payment. Should the dispute escalate to the building regulators tell em. " ... you paid a good $300 for the energy report...(humour) Cheers Chris Thanks mate, appreciated your advise! the same question, if i have upgraded ceiling insulation to R6 batt, do necessary blanket refit under colorbond roof? Re: Help !! Redo Colorbond Roof Installation 6Feb 20, 2023 10:17 am Anticon blanket under the sheets also dampens the impact sound of rain and hail Ideally it's best to have both what is the difference between anticon and ceiling Insulation Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Help !! Redo Colorbond Roof Installation 7Feb 20, 2023 11:21 pm ![]() Anticon blanket under the sheets also dampens the impact sound of rain and hail Ideally it's best to have both what is the difference between anticon and ceiling Insulation thanks mate Best Roof Plumbers Repair, Installation, and Replacement in Melbourne 🛠️🚿 📞 Call Now: 📞 (04) 8391 3988 Roof plumbing is an essential aspect of… 0 0 6 56898 |
