Browse Forums Building A New House Re: Storm water drainage in Brisbane 2Feb 15, 2023 8:03 pm We are Expert Consultant's, and we are here to help. Re: Storm water drainage in Brisbane 6Feb 16, 2023 10:30 am We are Expert Consultant's, and we are here to help. Re: Storm water drainage in Brisbane 8Feb 16, 2023 12:21 pm BuildingandLegal They don't have any rights to your property, their stormwater line is illegally discharging onto your property, no right of way..no easement. Stormwater is required to be connected to a legal discharge point (kerb, or stormwater line 'Council") or disposed of on-site, not run into your neighbours block. If they are hard to get on too, what option do you have? What would their argument be? "Your Honour, we're Sueing our neighbour because they cut off our illegal access to their property, where we are sending all our stormwater, as they wanted to build a house...the hide of them!" Thanks, I get the point. Re: Storm water drainage in Brisbane 9Feb 16, 2023 12:23 pm ponzutwo Ash19 BuildingandLegal Trace the line back to the boundary line, cut it off at the boundary, plug it with concrete. Thanks for the advice. Is that legal to do? Worried that might block the outlet of water and break the pipe. In that case the water would still flow onto our side since our block is lower. id be careful doing this. While the law is on your side at the moment, any negligence on your behalf, like plugging pipes could result if claims against you if there are damages suffered on their end. Same as if you killed a tree who's roots were causing problems on your side of the fence and the tree fell on the neighbors house causing damage. This could go both ways. Given they are hard to contact, go through legal channels so that the correct communications are sent to the correct addresses and if the go unanswered you can have records that back up any remedial actions you may need to take in their absence. Also if you get no response from those channels, you may be able to claim the economic loss suffered (penalties the builder is charging you) by their refusal to communicate or their inaction. Its messy, but dont you wont be in a legal grey area. Going legal is stressful. I have contacted them again. Hope they respond. Re: Storm water drainage in Brisbane 10Feb 16, 2023 12:47 pm The benefit of going legal, in my experience, is that it reduces the stress. They follow the correct proceedures, don't make expensive rookie mistakes, and take out any emotions. May be appropriate in your circumstance? Re: Storm water drainage in Brisbane 11Feb 16, 2023 12:49 pm Ash19 Going legal is stressful. I have contacted them again. Hope they respond. yeah obviously its ideal if you can work it out direct. But the suggestion of legal was in contrast to the suggestion of blocking the pipe. If you get to the point where the options are legal or block the pipe, go legal. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 8223 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 7099 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10890 |
