Browse Forums General Discussion Re: Steel beam location and impacts on costs/construction 2Jan 13, 2023 8:50 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Steel beam location and impacts on costs/construction 4Jan 13, 2023 9:03 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Steel beam location and impacts on costs/construction 12Jan 13, 2023 1:14 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Steel beam location and impacts on costs/construction 14Jan 16, 2023 7:23 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Steel beam location and impacts on costs/construction 16Jan 16, 2023 11:29 am You can use the limited info in the NCC steel supports for floor and roof loads.. What about Balconies with higher loads, structural masonry and hebel wall loads which relates to the initial post, where are they in the NCC? I see a reference to AS1720, AS4100, etc You've got the problem where the builder says I want an alternate method that's more costly, is he going to put in a cheap truss..? Check to see if your Building Surveyor and Council Building dept. will accept it and what their processes are? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ BTW, Here's the NCC where is the external Cladding? (1st post) another example of Pay a deposit and lol, we'll sort the cladding out later on... Along with the upgrade steel beams, steel columns, footings etc. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14584 Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12972 |
