slightly off topic, but would the epoxy be flexible enough to cover the fine cracks, if say it was applied straight after house handover and the house was still settling?
Browse Forums Building A New House Re: Slab cracks 31Jan 12, 2023 5:09 pm Grading should be done as part of the earthworks. You can't do the grading at that stage as the plumbing would be ripped out and there is limited access for an excavator. Re: Slab cracks 32Jan 12, 2023 5:11 pm groundzero They haven't got much of an argument that they did the drainage during construction. That doesn't comply with AS2870.Soil is not graded away, it actually looks like it slope towards the slab. Did they put in temporary down pipes when the roof was on? Even though they haven't done the right drainage during construction it doesn't necessarily mean it is the cause and whether it will continue to get worse. I would take some floor levels on the slab and you will see if it has significant movement. Then you can use the levels as a bench mark into the future and monitor if there is an underlying problem. No roof yet. Slab only went down 28 days ago, then frame a week after. They did put retaining wall in just after first site cut with AG but not connected and still not connected. Also just remembered about 8 weeks ago they broke the water metre and still haven't fixed. So leaking water at front of site still. Re: Slab cracks 33Jan 12, 2023 5:14 pm groundzero Grading should be done as part of the earthworks. You can't do the grading at that stage as the plumbing would be ripped out and there is limited access for an excavator. what? earth works are done befor ethe slab is formed. The grading is seperate and not considdered part of the earthworks, unless the entire slab is being built on an elevated and graded "pad" or position (which i think is shown in an older cornell engineers video), which realistically almost nobody does (cost). You cant grade away from a slab that doesn't exist, nor can you build up a grade to an edge that hasnt been formed and set. The practicality of the situation is this - when the formwork is pulled off, you add soil around the slab and grade/compact it. This is all done over the space of two to three days. They usually use a mini excavator, bobcat or a dingo depending on accesibility. no plumbing is damaged in the process unless you're retarded (admitedly some operators would be) issues arise not when there has been a singular event but constant and persistent failures to manage the moisture. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Slab cracks 34Jan 12, 2023 5:32 pm Noname Matevieflick groundzero
5.6.3 Drainage requirementsBuildings on moderately, highly or extremely reactive sites shall be provided with drainage systems designed in accordance with the following:[ol] [/ol] I have actually used this one and they continue to say they don't do any drainage until slab laid. I have 96 day time extension for rain and effects and I reject effects due to no drainage and why should I be penalised for them not following drainage. I will accept the bad rain days but the effects are on them. that's great, you have their negligence in 1writing! multiple times. Your engineering drawings have notes that say one thing, and then you have them saying they aren't complying with the engineering note son the engineering drawings. it is the literal smoking gun. I cant believe they'd be so stupid. actually.... i can. sad face. So if it come to it I would have a case? I legit thought I did but they they seriously don't care. Never reply to my rejection emails, only verbal calls the next day and tells me ,you can't reject them they are automatic. So disappointed as I was so excited to build a house. It's been a dream of mine and they treat clients appallingly. Re: Slab cracks 35Jan 12, 2023 5:35 pm You can grade it away from the building envelope, how do you think they know where to put piers in and the plumbing in before the slab is put down. Have you ever seen anyone build up soil against the slab and compacted it ? even though the regulations say it should be graded away and how to you compact soil on an angle? The reality is no one does it or very rarely does any builder comply with AS2870 as far as drainage goes. You can go to any new estate and see drainage isn't done. It usually is built up with gravels, rubble, tan bark which makes the drainage situation worse than simply not comply with drainage requirements. Re: Slab cracks 36Jan 12, 2023 5:51 pm groundzero You can grade it away from the building envelope, how do you think they know where to put piers in and the plumbing in before the slab is put down. Have you ever seen anyone build up soil against the slab and compacted it ? even though the regulations say it should be graded away and how to you compact soil on an angle? The reality is no one does it or very rarely does any builder comply with AS2870 as far as drainage goes. You can go to any new estate and see drainage isn't done. It usually is built up with gravels, rubble, tan bark which makes the drainage situation worse than simply not comply with drainage requirements. Yeah they have used chip bark. Our private inspector noted that it's not graded properly in our report. I was speaking to another SS from another company and he said they are supposed to do it but most don't. I feel that due to it being specified in soil report and drawings that site would be difficult in wetter months, they would follow drainage. Site was first cut in July (winter). Re: Slab cracks 37Jan 12, 2023 5:53 pm Matevieflick groundzero You can grade it away from the building envelope, how do you think they know where to put piers in and the plumbing in before the slab is put down. Have you ever seen anyone build up soil against the slab and compacted it ? even though the regulations say it should be graded away and how to you compact soil on an angle? The reality is no one does it or very rarely does any builder comply with AS2870 as far as drainage goes. You can go to any new estate and see drainage isn't done. It usually is built up with gravels, rubble, tan bark which makes the drainage situation worse than simply not comply with drainage requirements. Yeah they have used chip bark. Our private inspector noted that it's not graded properly in our report. I was speaking to another SS from another company and he said they are supposed to do it but most don't. I feel that due to it being specified in soil report and drawings that site would be difficult in wetter months, they would follow drainage. Site was first cut in July (winter). But you are right I have only seen one site graded away during excavation earthworks and only one after the slab was poured both times not that good but at least the builder made an effort. Re: Slab cracks 38Jan 12, 2023 5:57 pm Matevieflick groundzero You can grade it away from the building envelope, how do you think they know where to put piers in and the plumbing in before the slab is put down. Have you ever seen anyone build up soil against the slab and compacted it ? even though the regulations say it should be graded away and how to you compact soil on an angle? The reality is no one does it or very rarely does any builder comply with AS2870 as far as drainage goes. You can go to any new estate and see drainage isn't done. It usually is built up with gravels, rubble, tan bark which makes the drainage situation worse than simply not comply with drainage requirements. Yeah they have used chip bark. Our private inspector noted that it's not graded properly in our report. I was speaking to another SS from another company and he said they are supposed to do it but most don't. I feel that due to it being specified in soil report and drawings that site would be difficult in wetter months, they would follow drainage. Site was first cut in July (winter). No virtually no builder does it's standard practise not to do it and builders don't realise it leaves them legal vulnerable. Thats why photos are very important. Like noname said get an engineer to investigate it may not be a problem. Re: Slab cracks 39Jan 12, 2023 6:12 pm My drawings state with a site cut must have shallow agricultural drain or (swale drain) at base of the cut directly onto natural material. Then states refer to AS2870-2011 section 5.6.1, 5.6.2 and 5.6.3 and soil report. I think I got confused earlier with grading and drainage from site cute. Re: Slab cracks 40Jan 13, 2023 3:10 pm groundzero You can grade it away from the building envelope, how do you think they know where to put piers in and the plumbing in before the slab is put down. Have you ever seen anyone build up soil against the slab and compacted it ? even though the regulations say it should be graded away and how to you compact soil on an angle? The reality is no one does it or very rarely does any builder comply with AS2870 as far as drainage goes. You can go to any new estate and see drainage isn't done. It usually is built up with gravels, rubble, tan bark which makes the drainage situation worse than simply not comply with drainage requirements. to grade it away from the building envelope, youd be moving a $hittonne of soil, waiting till the slab is down is more economical and less work. Have i seen it? yes. my builder does this to literally every house they build. You compact it with the excavator. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. The CSIRO BTF18 explains differnt types of cracks and what "normal" is Google this and the top result is actually the latest version. You normally have to buy this from… 9 9595 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17881 Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 7307 |
