Browse Forums Heating, Cooling & Insulation Re: Cooling system 2Dec 04, 2022 2:18 pm Last time I built with a centralised system I was advised to upgrade to a larger duct size which I did and seemed to work reasonable well. The problem with all centralised systems is if a room door is shut the unit doesn't properly heat or cool that room because there is no path for air flow back to the central inlet. A few years ago I bought a 2 bedroom retirement unit with ducted heating. The first thing I did was add a couple of reverse cycle units. . . One in the lounge diner and one in our bedroom. 2 years later we found we hadn't used the ducted heating and removed it! The only additional heating we have is a fan heater for the bathroom The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Cooling system 3Dec 04, 2022 10:17 pm bashworth Last time I built with a centralised system I was advised to upgrade to a larger duct size which I did and seemed to work reasonable well. The problem with all centralised systems is if a room door is shut the unit doesn't properly heat or cool that room because there is no path for air flow back to the central inlet. A few years ago I bought a 2 bedroom retirement unit with ducted heating. The first thing I did was add a couple of reverse cycle units. . . One in the lounge diner and one in our bedroom. 2 years later we found we hadn't used the ducted heating and removed it! The only additional heating we have is a fan heater for the bathroom Thank you Bashworth Hi All, Our current 16 year old ducted gas heating is broken and needs an urgent replacement and appreciate any advise from the industry experts to make a decision for… 0 14131 2 12527 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 47121 |
