Browse Forums Building A New House Re: Site plan on slope land 2Nov 14, 2022 7:23 pm dhanz15 The reason you need a step in the slab is that the max you can cut & fill is 600mm which is why they have designed your home this way. If you were to raise the front to an FFL of 120.9 the front will be raised by just over 1000mm. I hope this makes sense Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Site plan on slope land 4Nov 14, 2022 8:30 pm On a different note if you move the rainwater tank, A/C etc to the opposite side you could have side access from the driveway side of the house. Re: Site plan on slope land 5Nov 15, 2022 11:49 am dhanz15 Thanks for the reply. Where did you get the 600 max cut and fill? Is this the maximum as per CDC requirement? Why not do a fill instead to match the elevation of the rear portion of the house? Yes that is the maximum allowed under the CDC guidelines. I have seen one council who allows 1000mm but this is rare so best to check with your council. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 226272 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25581 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 2691 |
