Browse Forums DIY, Home Maintenance & Repair 1 Sep 04, 2022 4:54 pm Hi Suspect there may be a leak in my house and wanted to off the main water supply. Found this outside my house instead. A silver triangular lever. Photo attached below Turned the lever. Water still runs when I turn on the tap. Turned lever back to where it was again and it seems to activate some sort of pressure, seems like some form of compressor and the water meter ran up 2 litres. Water also runs. So, am I stuck with no main tap to on/off? Is this some form of pressure adjustor? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: How to turn off main water pipe? 2Sep 04, 2022 7:11 pm The valve you show is a right angle ball valve. It soulds like when you turned it off some water started to drain out of the system. When you put it back you then refilled the pipes I wouls suggest you leave the taps on for a few minutes when you switch the valve. . . . you might find the flow has stoppped. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Until you find the cause of the flooding you need to take action to mitigate potential damage to your home. Get automatic float pump and dig a pit then connect to power… 2 5103 Hi all I'm currently building a duplex in Sydney and we need to do a new water connection to the second unit. The water main is on the other side of the road so we need… 0 4567 DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 6615 |
