Browse Forums Windows & Doors Re: 1900's front door paint stripping - Perth 5Apr 24, 2022 12:29 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: 1900's front door paint stripping - Perth 6Apr 24, 2022 7:35 pm chippy If you want to do it yourself, follow Stewie's advice and use a liquid paint stripper and then dispose of the stripped paint in the bin. If you want someone else to do it you can remove them and take them somewhere like the strip joint in Vic Park. They will put it in a tank and then strip it for you. Obviously that is harder if it's an external door that you are trying to keep. I just bought a small container of Poly Paint Stripper. If this isn’t as good as Citristrip I can take it back. Is it worth a try first? Re: 1900's front door paint stripping - Perth 7Apr 24, 2022 7:39 pm chippy If you want to do it yourself, follow Stewie's advice and use a liquid paint stripper and then dispose of the stripped paint in the bin. If you want someone else to do it you can remove them and take them somewhere like the strip joint in Vic Park. They will put it in a tank and then strip it for you. Obviously that is harder if it's an external door that you are trying to keep. I also read/watched on line another product called Peel Away 1. Looked effective but also seems pretty expensive too. Any thoughts on that product but if Stewie’s suggestion is best I’ll try that. Building Standards; Getting It Right! AS2047 Section 6 Page 31 speaks to Construction/Tolerances of Windows and external glazed doors in buildings Check also New South Wales Guide to Standards and Tolerances,… 12 24887 920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people… 4 1880 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9169 |
