Browse Forums Paving & Concreting Re: Opinion on concrete path please 4May 16, 2019 11:01 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Opinion on concrete path please 7May 16, 2019 3:33 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Opinion on concrete path please 8Mar 14, 2022 8:35 pm This was just one of many disasters on this build. We successfully got out of our contract because of their numerous failures in the build. We then went with Eden Brae and had a fantastic experience and well built home. Re: Opinion on concrete path please 9Mar 19, 2022 4:58 pm Hi there, First things first, yep it is a very messy job that has been done with no care taken. Things to consider.... is it ORG or a drain? so could it have been lowered or risen. Weep holes have a set level of which concrete can be at, ie: 50 mm belowbottom of weep hole. is the existing concrete part of the house slab? or could it have been removed? is there ableflex along the wall and has the what looks like water pipe been properly lagged as not to break if the concrete moves. why is there concrete all over the brick work and where are the expansion cuts for cracks. plus many?????? regards john johnny concrete Thank you for this! I started drilling the holes (white dots) but I guess I'll just fill them in. So I would glue the abelflex to the footings and then the poured… 2 11956 Building Standards; Getting It Right! Hi everyone, a contractor build a "retaining wall" for me and after 3 months there was a crack. They "repaired" the crack by adding an expansion joint where the crack… 0 21584 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 27444 |
