Browse Forums General Discussion Re: Storm water exit point 2Feb 25, 2022 11:54 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Storm water exit point 4Feb 25, 2022 5:57 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Storm water exit point 6Feb 26, 2022 8:35 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Storm water exit point 8Mar 04, 2022 5:29 pm kat4 SaveH2O It looks like a 90mm pvc pipe. If the pipe is full, you will lose hydraulic head to that point but there will still be positive head above that point. Looking at the photos, I would be surprised if you didn't still have an adequate hydraulic head. Apart from visuals, is there another reason for concern? My water isn’t getting onto street with the water covering the outlet Completly lost!! Where is your water going? If not coming out there it would back up your downpipes , no? Causing another problem Re: Storm water exit point 10Mar 07, 2022 5:34 pm You need to have a CCTV inspection as there should be noticable flow at the kerb if the downpipes are full. That is a hell of a lot of hydraulic head, you clearly have an obstruction in the pipe.The water level at the kerb is a red herring. How long have you lived in the house and is this a relatively recent problem? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7953 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6931 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10679 |
