Browse Forums Building A New House Re: Zerobound cladding installed wrong -help 2Feb 21, 2022 10:00 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Zerobound cladding installed wrong -help 4Feb 21, 2022 10:12 pm StructuralBIMGuy Track down the construction /engineering cross section detail for the Boundary wall contact the Council building department and ask to speak to a building surveyor about fire rating Cheers Chris Sorry to ask another question, do you know if cladding gets inspected at frame stage? Builder has inspection booked tomorrow. Then i will have my own private inspector go over it all too. Re: Zerobound cladding installed wrong -help 6Mar 03, 2022 5:34 pm StructuralBIMGuy Track down the construction /engineering cross section detail for the Boundary wall contact the Council building department and ask to speak to a building surveyor about fire rating Cheers Chris My private inspector has marked the wall as a major defect was excessive gaps and broken panels needing repairs Site supervisor said he past on report to carpenters to address. I rock up tonight and neighbors brick wall has gone up without repair my wall. In for a fight now to get major defect walls repaired before other neighbors wall goes up. Going to call council in morning, as this is a zerobound fore cladding wall. The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16403 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18776 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16975 |
