Browse Forums General Discussion Re: Land fall - Help please! 2Feb 14, 2022 2:48 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Land fall - Help please! 3Feb 14, 2022 7:44 pm bashworth There is not enough information from this plan. If each block was surveyed the normal contour internval is 0.2m but the contours shown on your plan might by the developers survey with a greater contour interval. There is some information about understanding site surveys at this link: site survey Thanks very much for coming back. Here's another picture which might help. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Land fall - Help please! 4Feb 14, 2022 10:08 pm Basically its 0.6m sloping from the front to the back. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. For those following along, the engineers have kindly come to the party and will be implementing a solution that should ensure adequate fall to the house connection. This… 8 15026 Looks like it, the only time a 6m cut would occur it if the builder cuts straight between those opposite corners. But if you have got the DA drawings and minimal… 3 8470 Thanks for replying. In my case, there’s no house for the weather to run back on to. There’s just a free fall to the ground, 3 m below. The balcony has 3 posts at the… 11 17461 |
