Browse Forums Building A New House Re: Asking about a soil test report 2Feb 06, 2022 5:59 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Asking about a soil test report 4Feb 07, 2022 8:56 am Not a bad idea getting another soil test done. The fact they moved you from H2 to P means you are in "Difficult" site category which will impact the design of your slab and footings. I would imagine for a P soil classification your engineer will propose making your slab stiffer with deeper footings, meaning higher cost for you. Re: Asking about a soil test report 5Feb 07, 2022 8:58 pm The "P" is not a soil type it is a site classification. It simply advises there is a "Problem" that the engineers need to consider when designing for the reactivity of the soils. A 'P' generally relates to Trees as you have said, or quite often uncontrolled fill, sometimes even bearing capacity. Getting another test may or may not give you a different classification to a H2. When the geo's take a sample of the bore holes they are taking approximately half a coke can worth of soil, the test is to see how much clay content is in the soil and when wet, how much it will expand. They generally do two bore logs to obtain an average view of the site. The New test may not draw up or take the same type of soils. When they take the sample back for their lab they conduct two tests, (1) shrink, to find how much the soil will shrink in dry conditions. This is done literally by placing a sample of the soil in an oven and measuring before & after. (2) Swell, a sample of soil is thrown into a container of water and left until it stops expanding, the sample is measured before and after to calculate its expansion. This provides a range the soil is expected to expand as the clays take up moisture and how much it will shrink in dry conditions. The engineer now has a range that the site in normal condition will move. Trees cause the "Average Moisture" to be abnormal to a localised area. The tree draws water out of the soil. Think of the root system as a dart board. Close to the bulleye (truck/root ball) the tree takes 80% water out of the soil, 1m ring out from the root ball the roots take 75% of the water in the soil, +1m out 65% water taken, +1m 55% water taken etc etc. This means the clay (soil) will expand / shrink at deferent levels. So the abnormal moisture is due to the tree's root system drawing the water out of the soil. If you have a H2 and you go shopping for a Lower classification, you are risking your home cracking for $4-$5k, and yes YOU are risking. Your contract has a duty of disclosure if you have a valid and correctly undertaken soil classification, and you get another as H1 and you don't tell the builder you may have a problem! We are Expert Consultant's, and we are here to help. Re: Asking about a soil test report 6Feb 08, 2022 8:08 am first time ive heard of somone wanting a less engineered slab. seriously, you are not the expert in these matters. Let the geotech engineers report the conditions and structural engineers design the slab to the conditions. This is to your benefit. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Asking about a soil test report 8Feb 09, 2022 2:32 pm Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Asking about a soil test report 9Feb 09, 2022 2:58 pm TIK123 Hi there, I had a report from a soil tester. Material taken from site for laboratory testing is of a H2. He changed the classification to P by the reason “due to the trees on site which may cause abnormal moisture conditions”. The point is, there were 2 average size palm trees on site. Is this reasonable? Can soil compaction be another alternative choice? So, the slab can be classified H2 instead of P. Should I have another soil test to confirm? I would appreciate for some advice. Thanks. You are always best to over engineer your slab. For our business, the 6 year warranty we give is for structure and waterproofing. We never ever want to have to come back and and fix either of those items. My business partner has a structural engineering background so takes the view that everyone of our slabs should be designed as though it is P rated site. We always do 450-500mm diameter piers to rock, and chuck as much steel in as we can. Better to be safe than sorry. Find other areas to cut costs in, like your tiles or appliances or something else. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Asking about a soil test report 10Feb 09, 2022 4:41 pm Better to be conservative and spend more on your slab and footings than be sorry later. I'm currently building on a H2 site and my slab engineering is designed using steel screw piers - more than 50 of em. Cost for steel piers was $6.5k and H2 slab upgrade was 5.5k. My base site works cost was more than 50K. Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 13970 Hi Building Expert, Thank you for the feedback, much appreciated, there is also a code of conduct for building surveyors which they need to follow as well. I am looking… 4 4124 Its never a good idea to sign a building contract without making sure everything is selected, soil test is done Is are dotted and Ts are crossed and without independent… 4 3030 |
