Browse Forums Pools & Spas 1 Feb 03, 2022 7:45 am Hi, The pool came with the house and I need some help identifying the model of the chlorinator and its cell. It must be quite old since I can't easily find it on google. Obviously the cell does work anymore and I would like to change it without changing the chlorinator. Thanks, Matt Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Chippy, no there isn't, gave it a really good look through and literally opened everything and checked all edges as well. Hence the question, just hoping someone would… 2 2265 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7623 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7865 |
