Browse Forums Renovation + Home Improvement Re: Should we go ahead with double story extension on top of 5Jan 23, 2022 11:08 am Regards, Colin Operations Director Homebuildguide.com.au Click Here For A Free eBook About Custom Home Building Re: Should we go ahead with double story extension on top of 7Jan 23, 2022 2:32 pm Homebuildguide-Colin Hey vov How's the project coming along? If you want to find out if the project is feasible, you should have an engineer assess it. The builders will not know anything about the foundations, so they will make assumptions. Civil engineers can tell you if it's feasible and what's involved. I've worked on a few of these in the past, so I know they can be done. In the worst case scenario, you may need extra reinforcements. A engineers report would cost you less than $1,000 & it would tell you if the project is feasible or not. From a quick look at your plan, it seems very straightforward. The only slightly tricky part might be the beams that must be cantilevered over the garage. However, it shouldn't be a major problem. What is your budget for the project? We couldn’t go ahead with that plan cause the proposed building have to sit back from rear wall. We still working on the drawing. Please find the latest picture for more information. Our budget between $200k-$240k Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Should we go ahead with double story extension on top of 8Jan 23, 2022 3:57 pm Thanks for sending that through. The proposed plan seems functional but the budget may end up being quite tight. The issue with working with existing building is that you never know what you will encounter as you open them up. Removing the roof will be a big job in itself. I would allow $10,000 for that alone to be safe. Once you've developed the drawings enough (and before you submit for planning), I would advise getting a BOQ done by an estimator. They will be able to detail & breakdown all the expected costs for the project. It might cost about $1,000 to get one but it would save you a lot in the long run. I'm sure there are some experienced estimators in your locality that have worked on these types of projects before. Regards, Colin Operations Director Homebuildguide.com.au Click Here For A Free eBook About Custom Home Building Re: Should we go ahead with double story extension on top of 9Feb 12, 2022 8:09 am Homebuildguide-Colin Hey vov How's the project coming along? If you want to find out if the project is feasible, you should have an engineer assess it. The builders will not know anything about the foundations, so they will make assumptions. Civil engineers can tell you if it's feasible and what's involved. I've worked on a few of these in the past, so I know they can be done. In the worst case scenario, you may need extra reinforcements. A engineers report would cost you less than $1,000 & it would tell you if the project is feasible or not. From a quick look at your plan, it seems very straightforward. The only slightly tricky part might be the beams that must be cantilevered over the garage. However, it shouldn't be a major problem. What is your budget for the project? Hi Homebuildguide-Colin, Do you have any recommendation for structural engineering firm? Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8518 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4107 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31293 |
