We are looking for what the Australian Standards are for buried High voltage electrical conduit ?
We hear it is 60cm, with Safety Tape being laid 20cm Above the Conduit to Warn people of the impeding danger below.
Browse Forums General Discussion Re: Australian Standards for Depth of Buried High Voltage El 2Jan 22, 2022 2:37 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Australian Standards for Depth of Buried High Voltage El 3Jan 22, 2022 4:37 pm Thanks Chippy, I am chasing this up for Rural Customers, as it is becoming a more common event, as more people are looking to Earn an income out of Solar Faqrms. There will only be Low Amp 240V AC feed and 100~800V DC running in the Conduit Trenches. I will go & try a few different searches, but found the Australian Standards site want to be Paid hundreds of Dollars, for what should be FREE information for Safety information. Dream Big, Work Smart, Not necessary Hard, and be kind to your Mum ! Re: Australian Standards for Depth of Buried High Voltage El 4Jan 22, 2022 11:04 pm The Raptor We are looking for what the Australian Standards are for buried High voltage electrical conduit ? We hear it is 60cm, with Safety Tape being laid 20cm Above the Conduit to Warn people of the impeding danger below. This is a Australia wide safety standard. Refer below excerpt AS/NZS 4026:2008 Electric cables Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Also see below Refer Electrical Safety Code of Practice 2020 The depth of cover for underground electric cables and underground control cables should not be less than: For open trench construction: • 750mm below the surface of a roadway for any cable installed under a roadway • 600mm below the finished ground surface for cables installed in other locations. https://www.worksafe.qld.gov.au/__data/ ... -works.pdf also refer https://www.ausgrid.com.au/-/media/Docu ... /NS130.pdf see Table 3: Standard cover and bedding requirements for conduits Re: Australian Standards for Depth of Buried High Voltage El 5Jan 22, 2022 11:32 pm The Raptor Thanks Chippy, I am chasing this up for Rural Customers, as it is becoming a more common event, as more people are looking to Earn an income out of Solar Faqrms. There will only be Low Amp 240V AC feed and 100~800V DC running in the Conduit Trenches. I will go & try a few different searches, but found the Australian Standards site want to be Paid hundreds of Dollars, for what should be FREE information for Safety information. Search for the electrical standards in the specific state. They are freely available. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Australian Standards for Depth of Buried High Voltage El 6Jan 23, 2022 1:10 pm Mox80 The Raptor We are looking for what the Australian Standards are for buried High voltage electrical conduit ? We hear it is 60cm, with Safety Tape being laid 20cm Above the Conduit to Warn people of the impeding danger below. This is a Australia wide safety standard. Refer below excerpt AS/NZS 4026:2008 Electric cables Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Also see below Refer Electrical Safety Code of Practice 2020 The depth of cover for underground electric cables and underground control cables should not be less than: For open trench construction: • 750mm below the surface of a roadway for any cable installed under a roadway • 600mm below the finished ground surface for cables installed in other locations. https://www.worksafe.qld.gov.au/__data/ ... -works.pdf also refer https://www.ausgrid.com.au/-/media/Docu ... /NS130.pdf see Table 3: Standard cover and bedding requirements for conduits Thanks Mox, Appreciate that, I will spend some time reading the information, although I am Not an Electrician, it will educate me more on the subject. The Doc's should assist our Rural customers looking to build a Large On-grid Systems we supply equipment to. We are finding many Rural people are looking to set up Solar Farms for a long term income. Dream Big, Work Smart, Not necessary Hard, and be kind to your Mum ! Re: Australian Standards for Depth of Buried High Voltage El 7Jan 23, 2022 1:12 pm chippy The Raptor Thanks Chippy, I am chasing this up for Rural Customers, as it is becoming a more common event, as more people are looking to Earn an income out of Solar Faqrms. There will only be Low Amp 240V AC feed and 100~800V DC running in the Conduit Trenches. I will go & try a few different searches, but found the Australian Standards site want to be Paid hundreds of Dollars, for what should be FREE information for Safety information. Search for the electrical standards in the specific state. They are freely available. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am surprised to hear every State has different Electrical Codes. Dam Government cronies, that have Never operated a Business ! Dream Big, Work Smart, Not necessary Hard, and be kind to your Mum ! Re: Australian Standards for Depth of Buried High Voltage El 8Jan 23, 2022 2:24 pm The entire system would need to be installed and signed off by a licensed electrician anyway, including all trenches for conduits. The licensed installers will be completely up to speed with the requirements in your state. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Australian Standards for Depth of Buried High Voltage El 9Jan 23, 2022 4:33 pm Yes, we understand that, we are just wanting to streamline the Red tape, as over 90% of DAT's are purchased & installed by the Farmer. Knowing what the Conduit Codes are is not Rocket science, it is simply digging a Trench to Code & then engaging an Electrician to Tick off the Installation. However, as 90% of Farmers are only interested of getting Totally rid of there Total Power, and it in Not worth the Puss-n-Pain of heading down the CEC path. As if there System is installed Off-Grid & Behind-the-Meter, you can give the Distributors & Retailers the Bird ! The BirdLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Dream Big, Work Smart, Not necessary Hard, and be kind to your Mum ! The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27442 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5534 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7165 |
