Browse Forums General Discussion Re: Site Costs for Spoil Removal 2Jan 04, 2022 9:51 pm It is not really possible to tell how much has been removed, what I would say is that those amounts are pretty reasonable charges. I would accept them unless you have reason to believe they are dishonest. Getting out of the ground chews up lots of money with not much to show. $3000 only really covers a large excavator and tipper for a day or two with a few loads a day depending on spoil dump site. Re: Site Costs for Spoil Removal 3Jan 05, 2022 9:01 am Jessikajade Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Could someone tell me if it is possible to calculate?? spoil removal amounts (tons) The block is only 352 m2 with a 8.5% slope and the home that is being built on it is??House Size (sq) 14.65????Total Area (m2) 136?? Width (m) 10.84 Length (m) 14.82?? Site status - platform slope is: Slope: 2 Degrees?? Fall direction: NW The??charge of $3000 in the contract price for Spoil Removal and then have been asked to pay a further $2000 as $3000 did not cover it, There is substantial amount of soil that has been cut and used as fill. Then their is?? this charge -??Provide a dropped edge beam of up to max 8 x brick courses to reduce and contain fill $3,630 through the front & RHS elevations in accordance with Authority requirements & to suit site??conditions in lieu of standard 2 course brick rebate. *Note: -??Includes spoil removal??due to excavating the dropped edge beams only Any info would be appreciated. Thankyou Did your designer not explain to you, Site Optimisation, Finished Floor Levels (FFLs), Cut and Fill , Balance Point (BP), Retaining Wall Heights and provide you with relevant data and costs. etc,etc. Engineering 3D Bim software can easily work out volumes m3, areas m2, lengths m. First you need a proper contour survey Site work costs Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Site Costs for Spoil Removal 4Jan 05, 2022 10:16 am Pulse It is not really possible to tell how much has been removed, what I would say is that those amounts are pretty reasonable charges. I would accept them unless you have reason to believe they are dishonest. Getting out of the ground chews up lots of money with not much to show. $3000 only really covers a large excavator and tipper for a day or two with a few loads a day depending on spoil dump site. Ok Thankyou for your reply. It is worded that the $3000 and the $2000 and part of the amount charged, are for Spoil Removal and doesn't mention excavation costs. A lot of soil has been used as fill from the back corner to the front. Anyway I am finding discrepancies and that there is definitely not a lot of transparency in any part of this experience, which is why I need to question things Not that they have started to build just started the cut and fill 3 weeks ago. PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10305 Is anyone building with Mojo and have a recent site cost tender 0 16007 Henley should give you some indication of site costs. Too many variable to give you any reasonable accuracy 1 1901 |
