Hi all,
We come to step where we need to locate and design the stair case.
Can anyone look at our propose plan and give me any feedback or ideas please?
Browse Forums Renovation + Home Improvement Re: Need help with Staircase location 3Oct 31, 2021 9:22 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Need help with Staircase location 17Nov 24, 2021 1:24 pm what is the reserve wall?? to make sure i clearly understand the problem please draw a line across where the plan has to be changed ....is the new upstairs 1.62 from the side boundary or 1.62 from the downstairs wall? Re: Need help with Staircase location 18Nov 24, 2021 1:39 pm oklouise what is the reserve wall?? to make sure i clearly understand the problem please draw a line across where the plan has to be changed ....is the new upstairs 1.62 from the side boundary or 1.62 from the downstairs wall? Downstair wall was built on the boundary line which is the red line in the picture. So the new upstair has to be setback from downstair wall. The blue line is where the maximum space we can have for upstair. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Need help with Staircase location 19Nov 24, 2021 3:42 pm Re: Need help with Staircase location 20Nov 24, 2021 7:05 pm hopefully this will work for you but you need to consider a front porch to improve the appearance from the street Thank you Oklouise, do you have any drawing to explain your idea? I also think the layout need stepback somewhere to make the appearance looks nicer. I’m think using the front part of the garage as well. In worse case we have to eliminate the ensuit to make more space for bedrooms. I prefer to keep the bedroom’s size as your prevous plan. Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2934 Staircases and sausages. Should thou wish to keep thy palate sweet for sausages, avert thine eyes from their crafting. 14 4880 ask the surveyor for clarification would be the logical approach 1 20459 |
