Browse Forums Windows & Doors Re: Framing Terminology 2Nov 22, 2021 4:18 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Framing Terminology 3Nov 22, 2021 5:49 pm chippy The entire thing that a door or window fits into is called a frame. The sides are called jambs. The top is called head The bottom is the sill. If the door frame is in an internal wall it typically has architraves around both sides to cover the gap between the wall sheeting and frame. If it's in an external wall there are reveals attached to the frame which cover the cavity space and then the architrave is fitted to the reveals to again cover the gap between wall sheet and reveal. Cavity slider is the same but obviously one side has a split jamb that allows for the pocket where the door slides into. Perfect, thank you! STEFF62 Framing should be fine, but he will only be able to nail the baseplates in, I wouldnt think you can dynabolt them after 24 hours. My question is, how is he… 1 5957 8 10099 Houses have been framed on floor joists since settlement, chipboard flooring is only around for 50 years or so, so why would it not be satisfactory? However exercise skill… 3 17136 |
