Browse Forums Owner Builder Forum Re: Recessed Curtain Pelmet in the ceiling 10Feb 28, 2023 6:52 pm JB1 I have them. Recessed so they go into the ceiling space. Note, you likely need to design it at engineering stage as your roof or posi truss will get in way. Any tips for someone who would like to have this done in their current home that's already been built? Does this require me to tear down our current roof and recessed lighting? Re: Recessed Curtain Pelmet in the ceiling 11Feb 28, 2023 9:44 pm nunelus JB1 I have them. Recessed so they go into the ceiling space. Note, you likely need to design it at engineering stage as your roof or posi truss will get in way. Any tips for someone who would like to have this done in their current home that's already been built? Does this require me to tear down our current roof and recessed lighting? Re: Recessed Curtain Pelmet in the ceiling 12Feb 28, 2023 10:51 pm JB1 nunelus JB1 I have them. Recessed so they go into the ceiling space. Note, you likely need to design it at engineering stage as your roof or posi truss will get in way. Any tips for someone who would like to have this done in their current home that's already been built? Does this require me to tear down our current roof and recessed lighting? Cool! Can you also add lighting to a bulkhead? (What exactly is a bulkhead lol?). I can't tell the difference from pictures between a bulkhead and a regular recessed curtain pelmet. Does it have something to do with putting up some sort of crown molding? Recessed Curtain Pelmet in the ceiling 13Mar 01, 2023 11:06 am See this photo https://trowelcraft.com.au/wp-content/u ... 24x768.jpg You can put lighting behind or under the bulkhead You could make the bulkhead wider and place cornices between the ceiling and bulkhead It’s fairly common Also check out Waldorf’s post above How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6111 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2488 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17286 |
