Browse Forums Building A New House Re: STEEL FRAMED HOME NEAR THE OCEAN - PERTH 4Nov 07, 2021 6:26 pm Just in the final stages of our build, 700m from the ocean, beside a saltwater lake. I used a crew from Bega called The Steel Framing Company using Truecore steel, frames stood for several weeks, were rained on, no sign of corrosion. I was particularly careful to avoid leaving any swarf in the bottom plate or any of the other framework once erected, and sprayed any cuts and holes . In our case the risk of termites far exceeds the metal mouse in my lifetime. Use a good thermal break, and choose cladding that is suited for use with steel. If you are constructing yourself, I recommend that you acquire a goog quality impact on driver, and right angle pact be driver, and use a tennis elbow brace..... C-section framing that forms a complete C rather than 2 fold is more expensive, but it is much stronge I used category 3 or 4 fasteners for everything. There is no reason that the steel frame won't last an easy 50 years as water leaks are really the only risk. At 300m from the beach you should use stainless colotbond roof sheeting regardless of your frame choice. Re: STEEL FRAMED HOME NEAR THE OCEAN - PERTH 5Nov 07, 2021 6:58 pm Thylacene Just in the final stages of our build, 700m from the ocean, beside a saltwater lake. I used a crew from Bega called The Steel Framing Company using Truecore steel, frames stood for several weeks, were rained on, no sign of corrosion. I was particularly careful to avoid leaving any swarf in the bottom plate or any of the other framework once erected, and sprayed any cuts and holes . In our case the risk of termites far exceeds the metal mouse in my lifetime. Use a good thermal break, and choose cladding that is suited for use with steel. If you are constructing yourself, I recommend that you acquire a goog quality impact on driver, and right angle pact be driver, and use a tennis elbow brace..... C-section framing that forms a complete C rather than 2 fold is more expensive, but it is much stronge I used category 3 or 4 fasteners for everything. There is no reason that the steel frame won't last an easy 50 years as water leaks are really the only risk. At 300m from the beach you should use stainless colotbond roof sheeting regardless of your frame choice. Hey thanks for your advice! That’s brilliant. Are you in Perth? Well they use fibre cement cladding with the steel frames and yes they will use colour one as well. But I just wanted to know how the rust would work. Also would it creak as everything expands etc? So you’re saying a two storey C shape with a Void would be more expensive than a normal square on square home? Re: STEEL FRAMED HOME NEAR THE OCEAN - PERTH 6Nov 07, 2021 7:44 pm holdtheline Thylacene Just in the final stages of our build, 700m from the ocean, beside a saltwater lake. I used a crew from Bega called The Steel Framing Company using Truecore steel, frames stood for several weeks, were rained on, no sign of corrosion. I was particularly careful to avoid leaving any swarf in the bottom plate or any of the other framework once erected, and sprayed any cuts and holes . In our case the risk of termites far exceeds the metal mouse in my lifetime. Use a good thermal break, and choose cladding that is suited for use with steel. If you are constructing yourself, I recommend that you acquire a goog quality impact on driver, and right angle pact be driver, and use a tennis elbow brace..... C-section framing that forms a complete C rather than 2 fold is more expensive, but it is much stronge I used category 3 or 4 fasteners for everything. There is no reason that the steel frame won't last an easy 50 years as water leaks are really the only risk. At 300m from the beach you should use stainless colotbond roof sheeting regardless of your frame choice. Hey thanks for your advice! That’s brilliant. Are you in Perth? Well they use fibre cement cladding with the steel frames and yes they will use colour one as well. But I just wanted to know how the rust would work. Also would it creak as everything expands etc? So you’re saying a two storey C shape with a Void would be more expensive than a normal square on square home? SE NSW. C section studs rather than U section, the extra lips add strength. You are correct, a rectangular home is cheaper to build, every feature detail adds cost. You might want to have a close look at what they are proposing, and check out the insulation values, you pay for a house once, you pay your energy bills at least 4 times a year Re: STEEL FRAMED HOME NEAR THE OCEAN - PERTH 7Nov 09, 2021 6:12 pm Here is an industry bulletin from Bluescope personally I don't like steel framing and much prefer timber. It's borderline with Bluescope is regards to neing that close to the ocean but I don't trust it, im in Secret Harbour on the golf course about 700m from the beach and the salt air attacks everything Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: STEEL FRAMED HOME NEAR THE OCEAN - PERTH 8Nov 09, 2021 6:18 pm Sorry that imagine is shocking it's Bluescope steel Technical Bullet TB-34, just google that Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14475 Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too... 3 9573 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7044 |
