Browse Forums Bathrooms and Laundry Re: WC waterproofing and floor waste 2Oct 18, 2021 8:12 am 3.8.1.2 clearly states water resistant. The general term of "water proof" usually pertains to protecting the floor to a standard which the installer finds acceptable and this typically means water proofing as is defined by the BCA because its easier and safer to go the extra mile and avoid future issues. Just waterproof the area. Its likely small and wont cost much and since your on timber joists its also piece of mind. Definitions below. Waterproof means the property of a material that does not allow moisture to penetrate through it. Water resistant means the property of a system or material that restricts moisture movement and will not degrade under conditions of moisture. Re: WC waterproofing and floor waste 3Oct 18, 2021 8:15 am Bimbob 3.8.1.2 clearly states water resistant. The general term of "water proof" usually pertains to protecting the floor to a standard which the installer finds acceptable and this typically means water proofing as is defined by the BCA because its easier and safer to go the extra mile and avoid future issues. Just waterproof the area. Its likely small and wont cost much and since your on timber joists its also piece of mind. Definitions below. Waterproof means the property of a material that does not allow moisture to penetrate through it. Water resistant means the property of a system or material that restricts moisture movement and will not degrade under conditions of moisture. Thanks Bimbob! The only part I don't understand is whether that then requires a floor waste to be added (additional cost)? Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4332 just talk to them, tell them it is unsightly and ask them for a solution. Any reasonable person would render it for you or do something similar. If they give you trouble… 4 18823 I have researched this topic in detail recently but for another state which has no licensing requirements at all so any handy man can waterproof any old way and not have… 1 8480 |
