Cool, good to know. I was afraid it would work like a “thin membrane” not letting much of the heating passing throw.
Thank you for that!
Browse Forums Eco Living Re: Best floor covering for keeping thermal mass 45Oct 07, 2021 3:28 pm gabrielpl I was hoping to get some advice on this matter too. This post is a little older now but if anyone could give their suggestion on two possible solutions for us, that would be great. We have an exposed concrete floor we'd like to add a covering as the workmanship of the burnished concrete was disastrous and we want to improve its appearance. We're considering either an 3mm epoxy or 3mm micro concrete covering layer to improve the levelling of the floor and aesthetics. The epoxy layer seems easier more readily available and with experienced tradies in our area (Tasmania). The micro concrete can be a little more challenging to get, possible from OZ mainland, and we'd be risking with tradies with no experience applying it. I am afraid a 3mm-thick epoxy layer might impact too much on the thermal absorption. I'd expect better absorption if using micro concrete instead. Any ideas or suggestions on the matter? Thank very much! We're pretty happy with our brushed finish but if I had the money I'd have gone for the Diamond Dave finish - mirror smooth, like a giant bench-top, although that does possibly bring more reflection. It's quite expensive though but incredible diamond-cut finish that needs no coating product as the stone is so finely cut. got it. thanks. I was looking for word ' Adobe' and added filter. all good. 12 14540 Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 18667 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16776 |
