Browse Forums Renovation + Home Improvement Re: Advice for Double story extension on waffle pod base ple 2Sep 27, 2021 6:34 am Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Advice for Double story extension on waffle pod base ple 6Sep 27, 2021 10:19 am Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Advice for Double story extension on waffle pod base ple 10Sep 27, 2021 1:06 pm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Advice for Double story extension on waffle pod base ple 11Sep 27, 2021 4:43 pm There doesnt need to be a cantilever at all? A steel beam could easily fit within the roof profile to pick up that corner, and columns/posts bearing on existing footings. Then, an internal beam to divide FJ loads. Only one pad footing would be required near bed 3, or beam extended to external wall and post/column provided. Real easy. Beams above are purple lines. Floor joists running perpendicular to beams. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice for Double story extension on waffle pod base ple 12Sep 27, 2021 5:39 pm moudzj There doesnt need to be a cantilever at all? A steel beam could easily fit within the roof profile to pick up that corner, and columns/posts bearing on existing footings. Then, an internal beam to divide FJ loads. Only one pad footing would be required near bed 3, or beam extended to external wall and post/column provided. Real easy. Beams above are purple lines. Floor joists running perpendicular to beams. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ easy, we have collectively designed it Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Advice for Double story extension on waffle pod base ple 14Oct 06, 2021 4:22 am vov Hi guys, Thank you very much for your advice. Thanks Moudzi. Very appreciate. I will update when we have Engineering involve in the floor plan. Vov I just realised I forgot to answer your question about engineering costs. I would budget $1500-2000 if you do your research. $4,000 worst case if you don't. By that I mean that there are engineers that will charge around $4,000ish but I think you should be able to get it done much cheaper with some research. Start by phoning a company that I have used a few times in Sydney, but they have a Melbourne office called Intrax. Phone Renan Yakoob 0429 500 218. I haven't used him in a couple of years but last time I did his price was reasonable. Also, I think Renan is now Sydney based but he will be able to give you details of his Melbourne colleagues. Alternatively, find a drafting company who has engineers in house in which case you shouldn't spend more than $11,000 for everything. Good luck with your project Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Advice for Double story extension on waffle pod base ple 15Oct 12, 2021 11:05 am Ashington Homes vov Hi guys, Thank you very much for your advice. Thanks Moudzi. Very appreciate. I will update when we have Engineering involve in the floor plan. Vov I just realised I forgot to answer your question about engineering costs. I would budget $1500-2000 if you do your research. $4,000 worst case if you don't. By that I mean that there are engineers that will charge around $4,000ish but I think you should be able to get it done much cheaper with some research. Start by phoning a company that I have used a few times in Sydney, but they have a Melbourne office called Intrax. Phone Renan Yakoob 0429 500 218. I haven't used him in a couple of years but last time I did his price was reasonable. Also, I think Renan is now Sydney based but he will be able to give you details of his Melbourne colleagues. Alternatively, find a drafting company who has engineers in house in which case you shouldn't spend more than $11,000 for everything. Good luck with your project Cheers Simeon Hi Simeon, Very appreciate your information. Just want to clarify, do we need a soil test done before contacting the engineer? Re: Advice for Double story extension on waffle pod base ple 16Oct 12, 2021 11:15 am vov Ashington Homes vov Hi guys, Thank you very much for your advice. Thanks Moudzi. Very appreciate. I will update when we have Engineering involve in the floor plan. Vov I just realised I forgot to answer your question about engineering costs. I would budget $1500-2000 if you do your research. $4,000 worst case if you don't. By that I mean that there are engineers that will charge around $4,000ish but I think you should be able to get it done much cheaper with some research. Start by phoning a company that I have used a few times in Sydney, but they have a Melbourne office called Intrax. Phone Renan Yakoob 0429 500 218. I haven't used him in a couple of years but last time I did his price was reasonable. Also, I think Renan is now Sydney based but he will be able to give you details of his Melbourne colleagues. Alternatively, find a drafting company who has engineers in house in which case you shouldn't spend more than $11,000 for everything. Good luck with your project Cheers Simeon Hi Simeon, Very appreciate your information. Just want to clarify, do we need a soil test done before contacting the engineer? I dont think so, the engineer will tell you what he or she needs Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Advice for Double story extension on waffle pod base ple 18Oct 12, 2021 11:35 am Hey vov You are missing/ haven't put up the engineering Plan showing the waffle grid rib locations? Those internal Light frame walls now become load bearing with the upper floor bearing down How about rib and wall thickening existing slab do they line up? You better get the complete set of engineering drawings and check Footing comparisons Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs The Soil classification has little to do with piers. The purpose of the classing of the soil is to identify the clay content and the "average expected range of movement… 2 9841 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8443 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4076 |
