Browse Forums Building A New House Re: Henley Or Carlisle Inclusions 9Sep 24, 2021 5:17 pm Our first home build journey https://forum.homeone.com.au/viewtopic.php?f=31&t=96594 Our second home build journey https://forum.homeone.com.au/viewtopic. ... 1&t=103533 Our build journey on Instagram https://www.instagram.com/cteafamily/ Re: Henley Or Carlisle Inclusions 13Sep 26, 2021 3:50 pm Hey Vipin, I am going with Canterbury grand deluxe 47 and the guy said we are waiting for the final quote but it may be vary and also he said you will get back bush fire $6500 money for sure but I don’t know why they are charging $7000 for developer requirement VipinMathew Goldy012001 Hey vipin Carlisle quoted me for site cost $17000, council $2000 and $7000 for developer and they also added around $6500 for bushfire zone can you pls share your quote both from Henley and Carlisle thanks Hi Goldy - what floor plan were you thinking of with Carlisle? I was planning on Illawarra Grand 36 with them and was provided with the following: Fixed site cost - $22K Council - $3K Dev: $5K Bush Fire: $5.5K. total quote: $447K For Henley - Floor plan - Palace 33: Site: 13K Council:2.7K BushFire: 4K Dev: None - I contacted Henley to confirm why this is the case. They are yet to get back, Total Quote: 427K Reading on the forums, it seems like Carlisle overquote in the beginning and then reduce it if required. The Henley sales agent mentioned that the fixed cost is based on the developer's primary engineering plan and variations shouldn't be huge (maybe 2-3K). Re: Henley Or Carlisle Inclusions 14Sep 29, 2021 10:18 am VipinMathew Hi All New to the forum here and I am in the process of locking down a builder for my first home. I've narrowed it down between Henley (Palace 33) and Carlisle (Colorado 34). The only thing that is bothering me is the inclusions. Carlisle seems to have much more inclusions (Luxe Pack) than Henley. Any recommendations on whom to go ahead with? The stand out items was: - Refrigerated cooling with Carlisle for $5000 vs Henley - $12000 - Flooring Pack included with Carlisle Vs $7000 for Henley - Security system included with Carlisle - Most Facades are free with Carlisle Vs thousands of $$ with Henley Just wondering who has better standard selections - Henley or Carlisle homes. thanks in advance, Vipin I can't answer your exact question, but in looking at value for money/cost effectiveness.cost savings, do also consider their construction methods. Carlisle for example use "Performance Solutions" - alternative construction methods to the Australian standards. I'm not an expert on this by any means, but the info here in this forum definitely gave me pause really consider what the use of 'performance solutions' for example might mean in comparing the overall cost/quality result of a build between two different builders. Re: Henley Or Carlisle Inclusions 15Sep 29, 2021 12:40 pm Lots of builders use alternate solutions to the standards. I can guarantee Henley do to. Some of them are better, some of them less so. All of them have to be verified/tested/proven to perform the same or better and certified by the relevant professionals. The challenge is understanding g the difference so that you can be informed. Ie the Carlisle waterproofing solution is approved because it performs the same, but requires yearly inspections to validate that it will continue to perform. That's a bad outcome for the client. A different solution to have weepholes lower in areas that are undercover gives a better aesthetic with minimal to no risk for the area. I don't know in other states, but vic recently made it a requirement for all performance solutions to be signed off by the client's as part of the building permit application. That document usually explains what it is, who certified it, what their qualifications are. You can use that summary for further questions/clarifications. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Thanks. There are plenty of builders around my suburb. I'll make sure to do some door-to-door knocking, or note their building details on the temp fence. 4 4746 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37142 Carlisle use to sneak a water resistant "Performance Solution" into their contracts. Have you checked your contract for same? 4 10201 |
