Browse Forums Building A New House Re: Building with Wisdom Homes 16205Sep 25, 2021 4:32 pm Sarah.z Flamingo Sarah.z Hi, I would like to know if the cost has been increased? I think once you have paid initial deposit, WH will lock your price for approx 12 month, I hope it helps Thanks a lot, may I ask is the tender price similar with final contract price? Thanks . This will depend on the provisional allowances you put in your tender to account for unexpected costs and the selections you make later in the building process. You need to anticipate how much extra you'll need for various parts of your build and add that in to your initial tender. I recommend putting higher amounts here that you think you'll need as you can always take these items out or change the amount in later administration stages. You are not expected to use/spend the money you add for provisional allowances. For example, I am building in a BAL 12.5 zone... as we would only know the actual cost of complying with the BAL requirements later in the build we added an $8000 allowance here in our tender. After our bushfire assessment came back and we knew what the requirements would be we found out it would only cost an additional $3,500. So, the $4,500 difference was taken off our final contract price. On the other hand, I did not put any provisional allowance in my tender for upgraded flooring and I ended up spending an extra $12,000 there. I could give many more examples, but the advice will remain the same... Research everything you think you'll want to upgrade or change and add provisional allowances in the tender to cover these costs. From my experience areas that would require significant allowances are kitchen, electrical, flooring, and site costs (if you have a sloped or otherwise difficult lot build on). Re: Building with Wisdom Homes 16206Sep 25, 2021 5:07 pm I think once you have paid initial deposit, WH will lock your price for approx 12 month, I hope it helps[/quote] Thanks a lot, may I ask is the tender price similar with final contract price? Thanks .[/quote] This depends on your personal choice and the land you have. Site cost and things you want to upgrade. Mine is $200k above their base price, this is because my site cost is high.[/quote] Hi Flamingo, thanks for the reply. If the base price is $450k, the tender price may be around $650k ( including site cost and promotion)? Did they ask you to pay extra after you signed your tender and contract e.g council regulation cost, water connection,excavation cost etc? Re: Building with Wisdom Homes 16208Sep 25, 2021 5:40 pm [quote="Sarah.z":2sopjnjm]I think once you have paid initial deposit, WH will lock your price for approx 12 month, I hope it helps[/quote:2sopjnjm] Thanks a lot, may I ask is the tender price similar with final contract price? Thanks .[/quote] This depends on your personal choice and the land you have. Site cost and things you want to upgrade. Mine is $200k above their base price, this is because my site cost is high.[/quote] Hi Flamingo, thanks for the reply. If the base price is $450k, the tender price may be around $650k ( including site cost and promotion)? Did they ask you to pay extra after you signed your tender and contract e.g council regulation cost, water connection,excavation cost etc?[/quote] After the tender, costs can vary for site costs, for instance hydraulics as that's not drawn up before tender. After contract if they find rocks on site that could add up too. Those are some examples. There's a good Facebook group too where others can answer these questions: https://www.facebook.com/groups/1823340 ... ?ref=share Re: Building with Wisdom Homes 16209Sep 25, 2021 7:37 pm jagberg [quote="Sarah.z":2sopjnjm]I think once you have paid initial deposit, WH will lock your price for approx 12 month, I hope it helps[/quote:2sopjnjm] Thanks a lot, may I ask is the tender price similar with final contract price? Thanks .[/quote] This depends on your personal choice and the land you have. Site cost and things you want to upgrade. Mine is $200k above their base price, this is because my site cost is high.[/quote] Hi Flamingo, thanks for the reply. If the base price is $450k, the tender price may be around $650k ( including site cost and promotion)? Did they ask you to pay extra after you signed your tender and contract e.g council regulation cost, water connection,excavation cost etc?[/quote] After the tender, costs can vary for site costs, for instance hydraulics as that's not drawn up before tender. After contract if they find rocks on site that could add up too. Those are some examples. There's a good Facebook group too where others can answer these questions: https://www.facebook.com/groups/1823340 ... ?ref=share[/quote] Appreciate your help ❤️ Re: Building with Wisdom Homes 16210Oct 19, 2021 8:31 pm I am reading through from page 400. On 615 so far and noone has asked yet, so I figure I should. I know it's extra for more then 1 colour of paint internally, but what about the ceiling? For instance if I did a light grey to all walls, would the ceilings be painted the same colour, or is it safe to assume the ceilings will be standard white? Re: Building with Wisdom Homes 16211Oct 20, 2021 5:04 am diepiggy I am reading through from page 400. On 615 so far and noone has asked yet, so I figure I should. I know it's extra for more then 1 colour of paint internally, but what about the ceiling? For instance if I did a light grey to all walls, would the ceilings be painted the same colour, or is it safe to assume the ceilings will be standard white? They are standard white Re: Building with Wisdom Homes 16212Oct 20, 2021 7:18 am diepiggy I am reading through from page 400. On 615 so far and noone has asked yet, so I figure I should. I know it's extra for more then 1 colour of paint internally, but what about the ceiling? For instance if I did a light grey to all walls, would the ceilings be painted the same colour, or is it safe to assume the ceilings will be standard white? All ceilings are painted white regardless. That been said, I think it is worth the extra cost (not sure but I think it was $600 for each color) of painting the color scheme you desire for living areas. Re: Building with Wisdom Homes 16215Oct 20, 2021 10:09 am diepiggy Hey suzK, yeah I figured that. But the skirting white isn't the same colour as ceiling white, so I wanted to check Yeah, it doesn't make sense because the skirting is always going to be a different paint to the walls even if the walls are white. We also paid an extra $750 to get the media room painted black. Re: Building with Wisdom Homes 16216Oct 20, 2021 10:28 am SuzK diepiggy Hey suzK, yeah I figured that. But the skirting white isn't the same colour as ceiling white, so I wanted to check Yeah, it doesn't make sense because the skirting is always going to be a different paint to the walls even if the walls are white. We also paid an extra $750 to get the media room painted black. $750? Has the cost of an extra colour gone up? Re: Building with Wisdom Homes 16217Oct 20, 2021 10:39 am diepiggy SuzK diepiggy Hey suzK, yeah I figured that. But the skirting white isn't the same colour as ceiling white, so I wanted to check Yeah, it doesn't make sense because the skirting is always going to be a different paint to the walls even if the walls are white. We also paid an extra $750 to get the media room painted black. $750? Has the cost of an extra colour gone up? No, we paid $600 for the light grey on walls but media room was $750 for black (incuding ceiling) Re: Building with Wisdom Homes 16219Oct 24, 2021 6:44 pm Woo! All caught up on the thread! Going for our tender presentation on November 5th. Building an Ambassador41 with a 3rd car garage. We are not in a rush, but would June/July be about right for starting construction? We are pretty organised, so don't think we will change plans after signing Re: Building with Wisdom Homes 16220Oct 24, 2021 8:03 pm Oh another question. We will be getting a wall oven and cooktop. While they are available on the Winning Electical website, they are about 30% more expensive then I can get them from Appliances Online. Will the kitchen/electrical team provision for the appliances for us to supply and install after handover? or is it not worth the hassle? I would be saving about $900 including installation if I bought seperately Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18749 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73804 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8887 |
