Browse Forums Building A New House Re: Concrete skirt question. Retaining wall or not? 18Sep 23, 2021 4:40 pm strannik it's not going to be 'easily argued' if there is a general slope in the land towards the neighbor's house. on the contrary, it will be 'easily argued' that the problems are of the neighbor's own (or rather their builder's) doing since they decided to cut the land creating opportunity for water to pool there. you could probably also just as easily argue that putting the house there actually protects them from most of the discharge, since it's collected by the roof as well as other side of the house, and directed into the drainage instead of flowing across the land. i would suggest to the neighbor that they should put a strip drain next to their wall to direct any water away. cause if you leave that gap, there's still a good chance there will be water pooling there, even if OP puts a strip drain on the edge of their skirting. that's what I'm planning to do in the new house we're building, cause my view is that it's my responsibility to protect my investment, rather than rely on neighbors to do so and argue the finer legal points when the issue arises. it's not a general slope. It's landscaping done by the builder as part of the foundation/drainage design. Sure the neighbours site cut is not the OPs fault, but again there is enough going on the OPs property for there to be plenty points of contention for an argument that escalates and result in reports, professional opinions etc. Expensive. Because it would be a civil matter, if the neighbor engages through that process, it wouldn't matter what the "real" story is or who is right, but sure as hell collecting and disposing of the water will result in a shorter lived argument that costs less than the one you're suggesting. the neighbor can do a bunch of stuff to protect their property too, but thats not in the OPs control. SO in my opinion, op should do what is in their control to head off any arguments or perceived liability that results from not doing it. seems pretty sensible to me. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Concrete skirt question. Retaining wall or not? 19Sep 23, 2021 4:51 pm the problem is that what you're suggesting isn't going to shorten the argument in the event the issue does arise. because it will still be a matter of reports and professional opinions on whether the drainage is adequate Re: Concrete skirt question. Retaining wall or not? 20Sep 23, 2021 8:36 pm [quote="strannik":3ftptx0k]the problem is that what you're suggesting isn't going to shorten the argument in the event the issue does arise. because it will still be a matter of reports and professional opinions on whether the drainage is adequate [/quote:3ftptx0k] It does shorten it because it wouldn't be a protracted argument. There wouldn't be a slew of conflicting opinions, because there is only one reasonable outcome - if the water is collected and diverted from the neighbours property, then the op hasn't contributed to the damage or acted in a negligent way. End of argument. I don't think any profesional would risk their reputation to provide a report that contradicts that. 😉 If you need help tying your shoelaces in the morning, I'll be busy, sorry. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Thanks for your reply! All valid points and I agree with you on many of them. I am in QLD, any recommendations on a construction lawyer would be helpful 3 2683 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5890 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16437 |
