Browse Forums General Discussion Re: Corner Lot — Double Storey Setback 8Jun 22, 2021 6:17 am Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Corner Lot — Double Storey Setback 9Jun 22, 2021 7:20 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Corner Lot — Double Storey Setback 13Sep 23, 2021 10:32 am It's same Victoria and whittelesea council. Also a house near by our lot but in different estate have build a corner lot without 900mm setback. So is it based on developer's guide and not with council requirements? Re: Corner Lot — Double Storey Setback 14Apr 04, 2022 3:45 pm cmani_19 It's same Victoria and whittelesea council. Also a house near by our lot but in different estate have build a corner lot without 900mm setback. So is it based on developer's guide and not with council requirements? Hi cmani_19 how were you able to proceed with this? Did you have to have to follow the 900mm requirement? Re: Corner Lot — Double Storey Setback 15Apr 04, 2022 4:55 pm Mblgggg1 cmani_19 It's same Victoria and whittelesea council. Also a house near by our lot but in different estate have build a corner lot without 900mm setback. So is it based on developer's guide and not with council requirements? Hi cmani_19 how were you able to proceed with this? Did you have to have to follow the 900mm requirement? You can file a application with council for getting exemption, council will go through your petition and then they will ask opinion from the people in your area. If they approve only if on one objects it. Else they will reject it. So withdraw the application for other factor. Re: Corner Lot — Double Storey Setback 16Apr 04, 2022 4:57 pm cmani_19 Mblgggg1 cmani_19 It's same Victoria and whittelesea council. Also a house near by our lot but in different estate have build a corner lot without 900mm setback. So is it based on developer's guide and not with council requirements? Hi cmani_19 how were you able to proceed with this? Did you have to have to follow the 900mm requirement? You can file a application with council for getting exemption, council will go through your petition and then they will ask opinion from the people in your area. They will approve only if no one objects it. Else they will reject it. We withdraw the application for other reason Re: Corner Lot — Double Storey Setback 17Apr 04, 2022 7:39 pm cmani_19 cmani_19 Mblgggg1 Hi cmani_19 how were you able to proceed with this? Did you have to have to follow the 900mm requirement? You can file a application with council for getting exemption, council will go through your petition and then they will ask opinion from the people in your area. They will approve only if no one objects it. Else they will reject it. We withdraw the application for other reason Yes, we need to follow 900mm setback requirements for double storey if you are not getting exemption from the council 1 4653 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 11660 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8542 |
