Browse Forums General Discussion Re: Damaged down pipes 2Sep 15, 2021 10:00 am Richie2262 I have two sink holes in my yard cased (sic) by cracked down pipes, Downpipes end at the stormwater connection. How do you know your problem is caused by cracked downpipes, have you dug down and had a look or is the connection covered by paving? Surely if the cracks are visible, they would have been noticed during PCI. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Damaged down pipes 3Sep 15, 2021 10:21 am SaveH2O Richie2262 I have two sink holes in my yard cased (sic) by cracked down pipes, Downpipes end at the stormwater connection. How do you know your problem is caused by cracked downpipes, have you dug down and had a look or is the connection covered by paving? Surely if the cracks are visible, they would have been noticed during PCI. Yer I payed for another plumber to come out and place a camera down the pipes and yes all pipes where cleared around them and they where wiping It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 1633 4 4006 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 4658 |
