Browse Forums General Discussion Re: What is this roof in bathroom? 2Sep 05, 2021 11:14 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: What is this roof in bathroom? 4Sep 05, 2021 5:24 pm building-expert It looks like perforated canine judging by the texture, are there any joining strips? Thanks so much for replying. I don't think there is any joining strips. Its in basically one large piece/sheet in bathroom ceiling. Are these usually hard to remove and to replace with plasterboard? Is perforated canine usually asbestos? Re: What is this roof in bathroom? 5Sep 05, 2021 6:02 pm loz1991 building-expert It looks like perforated canine judging by the texture, are there any joining strips? Thanks so much for replying. I don't think there is any joining strips. Its in basically one large piece/sheet in bathroom ceiling. Are these usually hard to remove and to replace with plasterboard? Is perforated canine usually asbestos? That should have read Caneite, a compressed sugarcane straw. If there are no joints then probably it is not Caneite. Removal of light fitting will expose material for identification. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: What is this roof in bathroom? 6Sep 05, 2021 7:11 pm In the first picture (link) you can see the joint. They've used a vee joint so I'd say it's either the canite or masonite. Both are timber fibre base so no asbestos to worry about. Canite will be roughly 10-12mm thick and quite soft, masonite is thin (around 5-6mm) and is fairly solid and hard and is a dark brown colour. I've never seen an asbestos sheet with holes like that and there'd normally be a joint strip or batten on the joints. I'm pretty certain you'll be right to remove and replace. Like building expert said, once you remove your light fitting you'll know. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: What is this roof in bathroom? 7Sep 05, 2021 8:21 pm An option may be to leave ceiling material in place and glue and screw plasterboard under and then finish off and paint. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: What is this roof in bathroom? 10Sep 08, 2021 4:14 pm Thanks for all your replies, useful information! I found an old picture of when repairs being done to a section. See below https://ibb.co/RBT442v Re: What is this roof in bathroom? 11Sep 08, 2021 5:08 pm It looks thin and the colour of masonite. Either way it doesn't contain asbestos so you can do as you please with it. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 2 11538 Hey all, Hoping for some inspiration for my bathroom laundry combo. The tiles are in good condition, as is the bathtub. I’ve given it a coat of white paint and added… 0 14459 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6981 |
