Browse Forums Building A New House Re: Downpipe at facade 2Aug 19, 2021 6:32 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe at facade 3Aug 19, 2021 7:02 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Downpipe at facade 6Aug 19, 2021 8:11 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe at facade 8Aug 19, 2021 11:59 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe at facade 10Aug 20, 2021 11:12 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe at facade 12Aug 20, 2021 11:38 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe at facade 14Aug 20, 2021 12:51 pm It also comes back to the maximum roof harvest area allowed which is the most important. Read my posts again in conjunction with BCA 3.5.3.5 but the plumber will have to check the roof harvest areas and the gutter high point positions.to map changes. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe at facade 15Aug 20, 2021 12:54 pm SaveH2O It also comes back to the maximum roof harvest area allowed which is the most important. Read my posts again in conjunction with BCA 3.5.3.5 but the plumber will have to check the roof harvest areas and the gutter high point positions.to map changes. Ok sorry, ive been reading the BCA 3.5.3.5 sorry ive missed out some infos ill try to ask my builder about this one Re: Downpipe at facade 16Aug 20, 2021 4:22 pm The tables for your 1:20 ARI and corresponding maximum roof catchment areas are 3.5.3.2a and 3.5.3.2b. Just remember that the roof "catchment" area is the area calculated after multiplying by 1.23 to allow for wind driven rain on your roof slope. The roof slope multiplier is shown in AS3500.3 which the BCA refers to. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe at facade 18Aug 20, 2021 4:40 pm You have to buy it, it is expensive. Try Googling "eaves gutter catchment area slope factor". Page 3. https://www.vba.vic.gov.au/__data/asset ... system.pdf Note that the other calculations in the VBA pdf are all done to the Australian Standards as Victoria has never adopted the inferior BCA as a Deemed To Satisfy (DTS) provision for roof drainage systems. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe at facade 19Aug 20, 2021 4:52 pm SaveH2O You have to buy it, it is expensive. Try Googling "eaves gutter catchment area slope factor". Page 3. https://www.vba.vic.gov.au/__data/asset ... system.pdf Note that the other calculations in the VBA pdf are all done to the Australian Standards as Victoria has never adopted the inferior BCA as a Deemed To Satisfy (DTS) provision for roof drainage systems. ill have to calculate my roof plan area. so that I can get the total roof catchment area Building Standards; Getting It Right! It's all good. You can get both wye piece and the coupling with or without thread. The cost difference is negligible and means the plumber only has to carry the single… 1 4928 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 |
