Browse Forums Building A New House Re: R value for New House Insulation 6Aug 03, 2021 8:53 pm I would say for $4k it is not worth it, I suggest you try and talk some sense into him that this simply can't cost that much as insulation prices are openly available, he needs to provide judgement where this 4k is coming from. Re: R value for New House Insulation 8Aug 09, 2021 5:48 pm chars0974 thanks bro. For external walls I would definitely go with R2.5, assuming it is for a standard 90mm stud wall. R2.7 gets some plasterers in a fizz because they reckon it pushes out a bit from the wall cavity. Anyhow we did a fair amount of our own insulation work on our current house and the advantage of the denser R2.5 over R2.0 is the ease of installation. It's basically firmer and holds better when you handle it and stays in place well once in the stud bay. Oh yeah obviously it also reduces temperature gains/losses, which is stating the obvious! Final comment I would rather have a good installation of R2.0 than a poor install of R2.5 if that makes sense. --------------------------------------------------------------------- Check our Homeone build blog here Re: R value for New House Insulation 9Aug 10, 2021 3:14 pm darb74 chars0974 thanks bro. For external walls I would definitely go with R2.5, assuming it is for a standard 90mm stud wall. R2.7 gets some plasterers in a fizz because they reckon it pushes out a bit from the wall cavity. Anyhow we did a fair amount of our own insulation work on our current house and the advantage of the denser R2.5 over R2.0 is the ease of installation. It's basically firmer and holds better when you handle it and stays in place well once in the stud bay. Oh yeah obviously it also reduces temperature gains/losses, which is stating the obvious! Final comment I would rather have a good installation of R2.0 than a poor install of R2.5 if that makes sense. will try R2.5 for external, thanks The last home I lived in didn't have a pool and when i went to sell it the agents were not happy, even telling me to put one in to sell the place. The agents weren't happy… 2 4246 As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is… 3 27364 They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9602 |
