Browse Forums Flooring & Floor Covering Re: Anyone know a Timber Flooring Supplier in Melbourne? 5Aug 28, 2007 10:39 am My Blog... http://ahouseonthehill.blogspot.com/ Re: Anyone know a Timber Flooring Supplier in Melbourne? 10Aug 28, 2007 1:51 pm Hi Colin, what countries do you import your timber from?
Is it on display at Bayswater? I might go and check them out. I went to *** and spoke with Mariana who was fantastic. Funnily enough she had just finished building with Henley and said that they were fantastic. She had previusly built with PD but didn't recommend them. Isn't it funny how the stories change between builders? Luck of the draw????? Re: Anyone know a Timber Flooring Supplier in Melbourne? 13Aug 29, 2007 4:10 pm Thanks Colin, i'll check it out a little closer to handover.
Hey can you please advise what the price range is on the basins? Some of them are absolutely gorgeous! Re: Anyone know a Timber Flooring Supplier in Melbourne? 14Aug 29, 2007 4:37 pm Hi Phoenix
The basin prices range from $230 for the smaller ones to $310 for those with the chiseled exterior and $380 for the large conical shaped ones. regards Colin No he can't. He's a spiderpig Re: Anyone know a Timber Flooring Supplier in Melbourne? 15Aug 29, 2007 5:19 pm Thanks for that Colin. Re: Anyone know a Timber Flooring Supplier in Melbourne? 16Aug 29, 2007 6:36 pm colinC Hi Phoenix The basin prices range from $230 for the smaller ones to $310 for those with the chiseled exterior and $380 for the large conical shaped ones. regards Colin Those are good prices Colin Are they straightforward for plumbers to install? Eimaj Re: Anyone know a Timber Flooring Supplier in Melbourne? 17Aug 30, 2007 3:49 pm Not a problem Eimaj. Plumbing is quite straightforward with a standard size waste. There are many already installed around Melbourne
regards Colin No he can't. He's a spiderpig Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15919 The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it… 5 3677 I haven’t. But have a Lowe Design home. Not only did I find Matt Lowe patronising and a bully, but the home is NOT TO CODE. I have water coming through the bricks… 1 14385 |
