Browse Forums Pools & Spas Re: Fiberglass Pool Bleaching under the water line 80Jul 27, 2021 10:59 am Thank you very much - to be honest I am devastated - our pool was a dark blue - it looks terrible now - not sure what to do - the cost of new gel coat is cost prohibited - 3m makes a gel coat restore with wax - I was thinking of trying that product with a variable speed buffer and a wool pad at around 800 rpm but afraid of burning the finish - I did try some hand wet sanding last fall but little success - I think a power machine is needed - could send a picture to me - thanks again - I appreciate your honesty Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20760 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 12679 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11321 |
